04-18-2018, 10:48 PM | #1 |
Newbie Join Date: Apr 2017 Location: Northcentral PA
| Motor for kit
What is the longest motor that will fit in the rock rey. bought a kit now need the stuff to go with it Thanks |
04-19-2018, 01:12 AM | #2 |
Quarry Creeper Join Date: Dec 2010 Location: Pontypool, wales
| Re: Motor for kit |
04-19-2018, 02:31 AM | #3 |
| Re: Motor for kit It’s not a straight forward fit though , the chassis plate needs to be hallowed out to receive the larger can and some plastic housing surrounding the transmission needs to be trimmed to get the pinion shaft in and the motor mount can be troublesome , Iv found if your running 16T pinion then need 17T position on motor mount Sent from my iPhone using Tapatalk |
04-19-2018, 02:37 AM | #4 |
| Re: Motor for kit this is the 1515 2200 kv There is also the 1512 2650 kv If your putting 1/8 power in it definitely 100% will need to build bulletproof diffs If you need anymore info about the diffs drop me a message Sent from my iPhone using Tapatalk |
04-19-2018, 10:10 AM | #5 |
| Re: Motor for kit
I was given a used yeti 3150 kv motor and Esc. Had 2 pack run thru it. This is what i was planning on putting in. Will it work? |
04-19-2018, 10:54 AM | #6 |
Rock Crawler Join Date: Apr 2017 Location: Northeast PA
| Re: Motor for kit |
04-19-2018, 11:54 AM | #7 |
| Re: Motor for kit
Thanks TooOldForThis was not sure |
04-20-2018, 09:44 AM | #8 |
| Re: Motor for kit
bought a hobbywing sct max 10 combo with a 550 sized 3200kv motor and 120 amp esc. was not sure about the ESC from axial.
05-20-2018, 08:56 AM | #9 |
RCC Addict Join Date: Mar 2011 Location: easton
| Re: Motor for kit
I’m running a hobbywing xr8 esc and a 3660 3600kv motor in a baja rey and it’s nuts. I don’t have a rock rey yet but I’m sure it would be just as crazy Sent from my iPhone using Tapatalk |
Motor for kit - Similar Threads | ||||
motor and esc for a xl kit | vito | Axial Yeti XL | 62 | 08-21-2017 12:41 AM |
Looking for motor for scx ii kit | J55TTC | Electronics | 17 | 02-28-2017 06:01 AM |
Motor for the kit | RemoteControl | Axial Yeti | 3 | 02-26-2016 05:21 AM |
GCM Motor mount kit help!!!! | crawler2.2 | Axial SCX-10 | 2 | 01-10-2016 03:27 AM |
