09-25-2018, 10:01 AM | #1 |
| ~TSS~ #TrackRey Build
been looking at these for months and finally pulled the trigger. everything came in on friday, and i spent the whole weekend building and was done by Sunday afternoon. plans are for it to be a track focused build. ie light and low with good handling and steering. parts ready for the rainy weekend diff and arms together. SSD bulkhead. didnt want to add the weight, but the strength and big bearings should be worth it. Rear axle done with SSD 3rd member, ended up tearing the front and rear diffs back down. There gear mesh was way too tight, luckily Losi put shims on both the ring, and pinion gears, that you can move to the other side or remove, this fixes it and made spinning them effortless, vs notchy and hard to turn. tub started skipped ahead to the cage, so i could start on the body painting while i finish up assembly. its a little flimsier than id like to see. but can support the entire vehicle weight. Reverse masked the cowl hood. More work, but easier because of the recess. front arms, bellcranks, and servo on. i also bought the HR front sway bars to help keep the chassis flat on track, but what they dont tell you is you must use HR lower a arms to use the sway bar kit, the stock arms dont have a bolt point for the sway bars. starting to look like something. Electronics in, rear axle and arb on, bumper supports. been years since i hand painted something. Came out looking like a drunk 3 year old did it, but it was relaxing as hell. cage and front shock tower on. diggin the look Assembly finished! thoughts/notes: axles and trans gears are super beefy had to mod the battery tray for my race pack (no leads, just 5mm bullets in cases removing the body mask was as mega pain. never had that happen before. front 4 hood/body mounts dont line up, 1/8" off i always wanted to cut off those giant front flares, but they come within 1/4" of the b pillar and shock hood hole, so it would leave the body too flipsy and probly break there. radiator flip up access to receiver/esc is cool the precision of both the plastics and body fit were really impressive. little things that were nice: precut/drilled body. HUGE time saver interior came in black ABS, didnt have to paint black the links and turnbuckles were all pre assembled and right length. driveshafts too. included light bar. thats kind of a big thing i guess. no one else does that. also the extra hardware and C clips they include were nice. Last edited by STANG KILLA SS; 09-26-2018 at 10:07 AM. |
09-25-2018, 10:11 AM | #2 |
| Re: ~TSS~ #TrackRey Build
was short lived. found out the BEC in the MMP was bad, so no test drive, had to tear it all down to remove esc to send off to castle. |
09-27-2018, 03:00 PM | #3 |
Newbie Join Date: Oct 2017 Location: Birmingham
Nice build. I've been impressed with mine other than the front slider shafts not being able to take the abuse I put them through with the diffs locked. I posted the pics in the CFOT thread a while back. I've been trying to figure out how you could unlock the rear and I guess it could be done but you'd have to machine the square end of the axles to accept the pins that would normally attach the spider gear to the outdrive. |
09-28-2018, 10:24 AM | #4 |
Thanks! yep thats gonna be tough part. |
10-06-2018, 12:29 PM | #5 | |
Newbie Join Date: Oct 2008 Location: Burbs
| Re: ~TSS~ #TrackRey Build Quote:
Try running the front semi locked with the ear plug putty solution. The diff loosens up from full locked once the putty warms up a bit. I posed the materials in my RR thread. Sent from my iPhone using Tapatalk | |
10-31-2018, 09:21 AM | #6 |
Pebble Pounder Join Date: Oct 2018 Location: boise
Always test electronics before final assembly! Sick build though man. Stoked to hear the turnbuckles come assembled. |
10-31-2018, 11:26 AM | #7 |
I wanna be Dave Join Date: Feb 2009 Location: Cowtown, USA
Very nice! Those preform very well on U4 type tracks, great design.
01-04-2019, 12:58 PM | #8 |
forgot to update this. raced it a few times. starting to get it dialed in suspension wise. but im at a loss for diff oil. i put 7k up front and 5k in the center (match to wha to what i run in my SCT, ie same 6.5lbs 4wd) but of course the rear is locked on the rock rey. any suggestions on what to run for track racing? the locked rear just wants to instantly pass the front any time you give more than a gently half throttle. and im only running 2S. i also changed shocks. im running proline prospecs rears up front. the stock prospec springs were too soft. so i ordered the additional proline spring set, they were also all too soft. i didnt realize this at the time but the front addition spring sets are much firmer rate than the rear. ended up putting some springs from a RTR losi that were firmer up front. worked great. on the rear im running the stock shock in the rear holes top and bottom to limit travel. im also running 1/2" fuel tubing limiters inside the shocks to also limit droop travel. (helps prevent traction/cornering rolls) running stock RR front springs on the rear. few pics Last edited by STANG KILLA SS; 01-04-2019 at 01:14 PM. |
~TSS~ #TrackRey Build - Similar Threads | ||||
~TSS~ Wampa Build | STANG KILLA SS | Axial Yeti | 50 | 05-07-2015 08:38 AM |
TSS Customer G55 Build | STANG KILLA SS | 1.9 Scale Rigs | 33 | 04-01-2011 08:24 AM |
~TSS~ Customer Build: John's G55 | STANG KILLA SS | 1.9 Scale Rigs | 29 | 03-31-2009 10:11 AM |
TSS based FJ40 Build | RexRacer19 | 1.9 Scale Rigs | 124 | 01-05-2009 05:17 PM |
