01-25-2019, 04:13 PM | #21 | |
Rock Stacker Join Date: Dec 2018 Location: Winchester
| Re: My RR build Quote:
My stock pinion was 12t. Idk which mounting holes to use honestly. I tried a few combinations of the number 16, 17 & 18 holes and can’t seem to get it right. Sent from my iPhone using Tapatalk | |
01-25-2019, 04:14 PM | #22 |
| Re: My RR build
WillyG on here was trying to help me out bc he said he has 17t, but even with his suggestions I wasn’t able to get it yet Sent from my iPhone using Tapatalk |
01-25-2019, 04:15 PM | #23 | |
Newbie Join Date: Jan 2019 Location: New Milford
Sent from my SM-G928V using Tapatalk | |
01-27-2019, 08:24 AM | #24 |
| Re: My RR build
Does this help? Is try the 2nd to last hole on the bottom right and the 2nd hole on the top left. Sent from my SM-G928V using Tapatalk |
01-27-2019, 09:40 AM | #25 |
| Re: My RR build
Yes it sort of helped. Thank you. I went back to using the stock 12t, but had to use a different hole for the one screw. Come to find out my issue with the 17t is that it’s 32p and not mod 1. Thanks for taking the time to send that. Sent from my iPhone using Tapatalk |
01-27-2019, 09:58 AM | #26 | |
Since my motor is out I just checked to see what I am running. I am running a 14t and I am using the 5th hole from the left on the top and the 5th hole from the right on the bottom (actually it's the 5th hole from either side, top and bottom. | |
03-06-2019, 11:49 AM | #27 |
| Re: My RR build
I’m running an 18t pinion now Sent from my iPad using Tapatalk |
My RR build - Similar Threads | ||||
JackedDriver's R1 Build (non-specific purpose / just wanted a good build) | JackedDriver | G-Made Crawlers | 12 | 01-12-2016 07:59 PM |
scx10 G6 2.2 Wroncho/Wrangler Build (AKA The Sleeping On The Couch Build) | Irishchamp | 2.2 Scale Rigs | 45 | 10-09-2014 10:26 PM |
Jeep scaler build and comp micro crawler build | droopmodmrc | Losi Micro-Rock Crawler | 1 | 12-25-2012 12:34 PM |
~53 Willys 2010 Comp Rig Build~ RC4WD MOA Worminator Build~ | 53 willys | General Crawlers | 108 | 11-28-2011 12:42 AM |
