03-06-2019, 12:23 PM | #1 |
Quarry Creeper Join Date: Nov 2018 Location: Oakley
| Powerstoke front shock mounts?
What are people using for the lower mounts? The mounts that come pre-installed on the shocks are too wide to fit in the control arms, but the ball-joints that come with the universal mount kit are sloppy((https://www.prolineracing.com/perfor...rdware-kit.asp) Are you using something else? Making the stock lower mounts work? |
03-06-2019, 12:57 PM | #2 |
| Re: Powerstoke front shock mounts? |
03-06-2019, 01:17 PM | #3 | |
| Re: Powerstoke front shock mounts? Quote: | |
03-06-2019, 01:19 PM | #4 | |
Spreading the plastics to put them in is fine. Just ensure nothing is binding and that the plastic isn't too stressed. It should be fine. | |
03-06-2019, 08:04 PM | #5 |
Rock Crawler Join Date: Sep 2015 Location: Lake Stevens
I had the same problem and made mine fit by swapping in Traxxas hollow balls from some rod ends I had in my parts bin. Sent from my iPad using Tapatalk Pro |
Powerstoke front shock mounts? - Similar Threads | ||||
Front upper shock mounts? | Adidas4275 | Axial RR10 Bomber | 6 | 05-18-2017 05:58 PM |
Significant play in the front shock mounts | fidelity101 | Axial Yeti XL | 3 | 04-10-2015 07:51 PM |
New GH Front Shock Mounts | GravelDuster | Axial Wraith | 3 | 07-06-2012 11:41 AM |
Front Shock Mounts | Land Crab | Axial Wraith | 7 | 01-27-2012 12:09 PM |
