Powerstoke front shock mounts? What are people using for the lower mounts? The mounts that come pre-installed on the shocks are too wide to fit in the control arms, but the ball-joints that come with the universal mount kit are sloppy((https://www.prolineracing.com/perfor...rdware-kit.asp) Are you using something else? Making the stock lower mounts work? |
Re: Powerstoke front shock mounts? |
Re: Powerstoke front shock mounts? Quote:
Spreading the plastics to put them in is fine. Just ensure nothing is binding and that the plastic isn't too stressed. It should be fine. |
Re: Powerstoke front shock mounts? I had the same problem and made mine fit by swapping in Traxxas hollow balls from some rod ends I had in my parts bin. Sent from my iPad using Tapatalk Pro |
