Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Losi Rock Rey
Thread: Better motor for RTR Rock Rey
Old 01-04-2020, 09:47 PM   #1
Default Better motor for RTR Rock Rey
I bought a Rock Rey for my son to play along with my Bomber. I installed a 10 tooth pinion gear and have been running it on 2s for him to learn on. It is still plenty fast but trying to do even mild crawling it is cogging pretty bad.
Is there a cheap motor swap I could do with the stock esc that will improve this? I'm not looking to put an expensive setup in this for a 7 year old. Stock motor says 2800kv 6 pole. What size motor is this? What kv range would be recommended? I still have the stock 12t pinion I could use on a slower motor later on.
Sent from my SM-G892A using Tapatalk
Crawler1995 is offline   Reply With Quote
Old 01-13-2020, 12:28 PM   #2
Default Re: Better motor for RTR Rock Rey
Stock motor is a 3660 size motor 36mm round and 60mm long Rcjuice has lots of inexpensive great motors a 3665 2600kv motor should work.
DatsunDave is offline   Reply With Quote
Old 01-21-2020, 10:04 PM   #3
Thanks I will look into them!
Better motor for RTR Rock Rey - Similar Threads
Help an old timer pick a Motor/ESC for Rock Rey ?? crunky Newbie General 1 01-26-2019 07:31 AM
Rock Rey kit suggestions for motor/esc servo mikeh0314 Losi Rock Rey 27 10-31-2018 01:42 PM
Cheap brushless motor / ESC for Rock Rey MrBlank Electronics 16 08-01-2018 10:43 AM
Losi Baja Rey and Rock Rey Aluminum Hop-ups - In Stock! RPP Hobby RPP Hobby 4 03-22-2017 04:30 PM
