Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Max Speed Technology CFX
Thread: MST CFX-W arrival
Old 12-31-2016, 10:47 AM   #41
Default Re: MST CFX-W arrival
Originally Posted by XSRCdesign View Post
I dunno.. I mean you are gaining diff clearance.. but losing axle c clearance? Weird
It may be for clearance at the wheel.
hotwheels000 is offline   Reply With Quote
Old 12-31-2016, 10:52 AM   #42
That is on the other side though?
XSRCdesign is offline   Reply With Quote
Old 12-31-2016, 11:36 AM   #43
Ok, limited time today for this but got done what I set out to do and that's comparing portal to portal.
Mad Moose preproduction vs. MST CFX-W
For starters, my Moose Knuckles have a full season on them and gave me very little issue (broke cvd by not trimming my end points properly and pinching up a very heavy class 1 rig at the same time).
The MadMoose axles are maybe an 1/8" narrower.
The issues I have right off the bat is that the MST axle isn't designed for CMS and will have a servo mounted on the axle top. Both axles are the same so making them 4ws is easy enough like the old ax-10 was.
The other issue is the retro, 1980's king pin design on the MST, Phillips head shoulder screw and all.... seriously? Lol.
The MadMoose is a much better design and using bushings makes it easily rebuildable as needed.
The C being removable and clock-able on the MST is nice, more on that later.
The gear designs, small multiple contacts vs beefy
Wheel fitting is about the same. I run RC4WD 1.55 steelies on my Moose axles and are likely the smallest that will fit. The MST fits them the same with a small amount of rub.
Both easily accept kit axial 1.9's
I did try to fit up a set of 1.9 RC4WD rear beadlock wheels but they aren't even close. Widener would be required for both.
Sent from my iPhone using Tapatalk Pro
jrkilburn is offline   Reply With Quote
Old 12-31-2016, 11:46 AM   #44
I wonder how easy it is to get replacement parts? Any insight?
bilinvic is offline   Reply With Quote
Old 12-31-2016, 11:47 AM   #45
CVD design is also worth noting as well as the gears for ring and pinion.
MadMoose has been testing theirs for a while and has a solid solution in my opinion and are obviously beefier.
The Moose axles use Vaterra ring and pinions and are a larger pitch than the MST.
All in all, as with most RC products, these two are application based comparable.
I love the scale, CMS ready, pass through ready, and great looking Mad Moose portals. They have served me well in trail and competition based use.
The MST's will see the same duty over this season and I like the splines C's that may give more adjustments for pinion angles. We will have to get them on rocks and trails to know more.
Old 12-31-2016, 11:47 AM   #46
Not many us Mst dealers and the ones that are I don't think are carrying the Mst crawler stuff but plenty on ebay is you are okay with waiting.
fr8cture is offline   Reply With Quote
Old 12-31-2016, 12:00 PM   #47
Almost forgot clearance!
Here they are side by side. Same tires, no weights.
Both have the same center clearance
The MadMoose reigns king for portal height!
Old 12-31-2016, 12:19 PM   #48
No idea.... support from Mad Moose is, and has been, easy. Considering the kit made the trek from HK in seven days is promising.
Old 12-31-2016, 12:20 PM   #49
I like the 4 gear setup on the MST.
Brake Weight is offline   Reply With Quote
Old 12-31-2016, 01:17 PM   #50
The MST gears really don't look too bad reminds me of the t-case gears in the scx10 II.
Old 12-31-2016, 01:48 PM   #51
Agreed, they look and feel the same as ascender and scx10ii gears.
Old 12-31-2016, 02:09 PM   #52
Moderator Rule Breaker
eric113's Avatar
I'm liking the mst. The only thing I'm not liking the high placement of the motor. But that could be fixable.
Jr, so the mst chubs will fit on the scx10.2 axles? Or on mst could you use axial universals? The tangs on the axle shafts look the same.
eric113 is offline   Reply With Quote
Old 12-31-2016, 02:10 PM   #53
Was wondering the same.
Old 12-31-2016, 03:34 PM   #54
IJr, so the mst chubs will fit on the scx10.2 axles? Or on mst could you use axial universals? The tangs on the axle shafts look the same.
Interesting...
Old 12-31-2016, 08:14 PM   #55
The motor isn't as high as it looks. The top of the can is about even with the shock tower top.
Yes, the spline count is the same as the scx10.2 axles. The axle shafts tangs are different. I am sure that someone out there will make an axle shaft to blend the two and result in a portal hybrid. If I had another week off I could probably see what it would look like.
Sent from my iPad using Tapatalk Pro
Old 12-31-2016, 10:58 PM   #56
eric113's Avatar
Can you get pics of the tangs of the mst cvd's and scx10.2 universals tangs?
Old 01-01-2017, 06:27 AM   #57
I should be able to do that later today.
Old 01-01-2017, 10:42 AM   #58
Are there any spots on this truck that come with bushings instead of bearings? If so could you post up the measurements and quantities? I have a kit coming and want to build it with full ball bearings. Thanks
f150monster is offline   Reply With Quote
Old 01-01-2017, 10:57 AM   #59
The instruction manual can be downloaded (PDF) on this page:
https://www.asiatees.com/display?MST...d=134576&pid=1
Old 01-01-2017, 11:15 AM   #60
Bearings everywhere except in the portals for the idler gears.
MST CFX-W arrival - Similar Threads
Mst cfx-w Rcdood Chit Chat 50 01-11-2017 07:55 AM
has any one seen the new mst cfx w rig steven318is Newbie General 10 12-08-2016 10:15 AM
Arrival Time? Jslick Northeast National Championship 8 07-10-2015 05:59 AM
Arrival time on Friday. SubaruDriftBoy Northeast National Championship 7 06-10-2013 03:55 PM
AX10 arrival? HULK Newbie General 5 09-15-2007 10:49 PM
