01-01-2017, 02:45 PM | #61 |
Rock Stacker Join Date: Jan 2017 Location: On RCC Studying
| Re: MST CFX-W arrival
I almost picked one of these up for my first scale truck. I went with the V2 Axial due to local support. This will be my second rig purchase. Keep up the wonderful build! I really like the beefy portal axels. |
01-01-2017, 03:46 PM | #62 |
Newbie Join Date: Dec 2015 Location: Québec
Nice i like it
01-02-2017, 10:11 AM | #63 |
Rock Crawler Join Date: Jul 2005 Location: MD
Home stretch! Axles ready to go on the chassis Driveshafts What's interesting here is they sent short and long center shafts. So spare shorts and four additional longs as it's assembled using the shorts. There is no mention about making this a longer wheelbase but the chassis has extra holes stamped in to do so. Sliders and battery mount As it sits on its wheels and tires provided. I may have a small collection of bodies "in stock" to set on for scale of the chassis. I'll let you all tell me what looks best. RC4WD Blazer Tamiya Toyota Tamiya Clod RC4WD D90 China something Hummer H3T I hope you all enjoyed the build. Time to get some electronics to make this thing a driver and to pick a body..... Sent from my iPhone using Tapatalk Pro |
01-02-2017, 10:16 AM | #64 |
Blazer if you adjust those links.
01-02-2017, 10:27 AM | #65 | |
| MST CFX-W arrival Quote:
So I looked into this quite a bit this morning, which involved tearing down my scx10ii. Without some serious machining, the parts are just enough different to not allow a hybrid of these axles together. You would also have to work out a CMS solution if you did. Here are some photos from my findings- Side by side Differential side by side With machining of the tang to fit the scx10ii spool, there is enough depth. What the MST would look like on the scx10ii just for kicks If you wanted portals on your scx10ii or ascender chassis, just buy the MadMoose and be done with it. They already have CMS worked out, they will be offering a leaf spring seat with the production version and it has a larger, what I would call, "window of clearance" over all. The MM axle has about 140ish mm of square clearance between the portal boxes all the way up to the axle tubes. The MST is tapered due to the Chub design from 140ish to 115 at the tube. Hopefully all this work and comparisons let you each "make smart choices" based on your individual needs. Sent from my iPhone using Tapatalk Pro Last edited by jrkilburn; 01-02-2017 at 10:33 AM. | |
01-02-2017, 10:30 AM | #66 |
Quarry Creeper Join Date: Jun 2007 Location: Loiret, France
Tamiya Toyota is the one I prefer between bodies you show |
01-02-2017, 10:58 AM | #67 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
Can you tell me the ring and pinion count on both the mst and scx.2
01-02-2017, 11:13 AM | #68 |
^^^^^^^^^^ tooth count ^^^^^^^^^^^^^^^^^^^^^^
01-02-2017, 11:19 AM | #69 |
Newbie Join Date: Jul 2015 Location: United Kingdom
Fantastic build thread. Thanks. Mine arrives this week and as a relative newbie very much looking forward to it. I have bought a Jeep Nukizer body which is 313mm wheel base. Initially have just bought some 6/7mm spacers and longer grub screws to lengthen the links. From what you have just said the shock towers would need to be moved further apart and may need to use the long center shafts. Not precise but will that be good enough? +1 for the Tamiya Toyota |
01-02-2017, 11:49 AM | #70 | |
| Re: MST CFX-W arrival Quote:
The shock hoops can be moved and they have three positions to choose from. It sounds like you will be good to go with your plan. Sent from my iPhone using Tapatalk Pro | |
01-02-2017, 11:59 AM | #71 |
| Re: MST CFX-W arrival |
01-02-2017, 12:04 PM | #72 | |
Definitely adjustable but would require a 10-12mm spacer for the lower links and the grub screws as mentioned. Sent from my iPhone using Tapatalk Pro | |
01-02-2017, 01:01 PM | #73 |
Thanks. Not having done this before, 10mm spacing on both sides = 20mm total. Standard wheelbase is 300mm so is would this +20mm be too much to get to 313mm?
01-02-2017, 01:12 PM | #74 |
I kinda like the H3T body. |
01-02-2017, 01:14 PM | #75 |
10-12 mm is the total you have to add, it's only 3 mm on each side of each link If I take this chassis, I would like to put on it Axial Cherokee body, and it's the same, 313 mm wheelbase |
01-02-2017, 01:22 PM | #76 | |
I happen to have one of them here too, forgot about it. Dead on Sent from my iPhone using Tapatalk Pro | |
01-02-2017, 01:25 PM | #77 |
01-02-2017, 01:25 PM | #78 |
01-02-2017, 01:28 PM | #79 |
Hmmm.... Nahhhh, lol Sent from my iPhone using Tapatalk Pro |
01-02-2017, 03:38 PM | #80 |
Newbie Join Date: Oct 2016 Location: billingborough, lincolnshire
fantastic build up and great with the info, has answered some questions for sure thanks.
MST CFX-W arrival - Similar Threads | ||||
Mst cfx-w | Rcdood | Chit Chat | 50 | 01-11-2017 07:55 AM |
has any one seen the new mst cfx w rig | steven318is | Newbie General | 10 | 12-08-2016 10:15 AM |
Arrival Time? | Jslick | Northeast National Championship | 8 | 07-10-2015 05:59 AM |
Arrival time on Friday. | SubaruDriftBoy | Northeast National Championship | 7 | 06-10-2013 03:55 PM |
AX10 arrival? | HULK | Newbie General | 5 | 09-15-2007 10:49 PM |
