12-08-2017, 05:36 PM | #1 |
Quarry Creeper Join Date: Dec 2016 Location: DA U.P.
| Running rear motor and front battery setup on CFX?
I know this goes against "crawler rules" but planning on running the motor and trans in the rear and battery upfront so i can get my body slammed all the way down on the rails. Servo linkage will be moved to opposite side and motor will be run in reverse with zero degree timing. Do you see any issues with this? |
01-02-2018, 10:21 AM | #2 |
Rock Crawler Join Date: Jul 2005 Location: MD
| Re: Running rear motor and front battery setup on CFX?
Desmond Mooney is running that set-up on his Mooney-Mog. https://www.facebook.com/photo.php?f...type=3&theater He doesn't seem to have any issues that I am aware of. |
03-13-2018, 03:41 AM | #3 |
Rock Stacker Join Date: Oct 2014 Location: New zealand
The only thing i can think of is that if youre just swapping the axles over and reversing motor direction, youll have to swap the front and rear crossmembers that go on the end of the chassis. Only one of them has extra space for the servo to clear under articulation. If you dont you'll get clearance issues with te servo. Also im not sure if the wheels will clear the battery when steering, but thats only if you put the battery across the chassis like the stock rear position. Mst cfx Axial wraith Axial yeti 8x venom creeper |
03-13-2018, 04:15 PM | #4 |
Newbie Join Date: Mar 2018 Location: Portugal
Can we see photos of a front lipo on the Mst CFX-W? From Facebook i can't see nothing.... Someone could share those photos? |
Running rear motor and front battery setup on CFX? - Similar Threads | ||||
What motor and battery after you guys running? | nate94gt | Vaterra Ascender | 6 | 10-07-2017 06:15 PM |
CFX-W Front Motor Compatibility | electrichead | Max Speed Technology CFX | 7 | 06-11-2017 08:08 PM |
Running different gear ratios, front and rear | 4WDwannabe | Axial SCX-10 | 18 | 03-14-2012 07:20 PM |
Anyone here running a 4 link setup on the rear of your SCX10? | BigB_117 | Axial SCX-10 | 36 | 07-12-2009 07:41 PM |
how much front weight are you running with a droop setup? | halfcab | Tamiya TLT Crawlers | 4 | 08-13-2007 02:02 PM |
