Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Max Speed Technology CFX
Thread: Ideal size of shock absorbers for mst cfx-w
Old 11-03-2019, 09:12 PM   #1
Default Ideal size of shock absorbers for mst cfx-w
Hi guys, I have a mst cfx-w and I want to change the plastic shock absorbers as standard for aluminum ones. My doubt is in the ideal size for these, since very long ones will lift the center of gravity quite a bit, but I want some that have a longer distance than the original 70mm. I have thought about installing about 80 or 90 mm, what do you recommend? If someone already did what is the performance? Thanks in advance and greetings ....
estbx is offline   Reply With Quote
Old 11-04-2019, 12:42 PM   #2
Default Re: Ideal size of shock absorbers for mst cfx-w
You can go with some 90mm shocks and mount them next to the links. You'll have to get longer screws. It will lower the rig a bit.
mhowzit is offline   Reply With Quote
Old 11-06-2019, 07:29 AM   #3
Good idea, I had not thought about it, thanks for your prompt response, regards ✌️
Old 11-08-2019, 12:26 PM   #4
No problem. I've been meaning to do it to mine, but I am get sidetracked and end up working on other things.
Tags
crawler, mst, mst cfx-w, shocks
Ideal size of shock absorbers for mst cfx-w - Similar Threads
MST CFX... Out with the old in with the CFX... Old n ratty Max Speed Technology CFX 24 01-13-2019 08:57 AM
Mst cfx-w nerdtek Max Speed Technology CFX 0 02-24-2017 08:01 PM
New G-Made RSD Shock Absorbers LSXGMC General Scale Talk 21 01-22-2017 02:08 AM
Mst cfx-w Rcdood Chit Chat 50 01-11-2017 07:55 AM
