01-13-2016, 01:34 AM | #21 | ||
Pebble Pounder Join Date: Apr 2013 Location: Germany
| Re: Wranger YJ on MST CMX I think it took about 4 or 5 hours, having a couple of beers with it Quote:
The regular 5 mm | ||
01-22-2016, 08:07 AM | #22 |
I wanna be Dave Join Date: Nov 2014 Location: West Texas
it's a nice looking rig. From your measurements it a bit smaller than a scx10 dingo. The 265mm is that the longest the frame can be extended without lots of fab work?
01-22-2016, 08:22 AM | #23 |
I'd say it's much smaller than a SCX ;) And as the frame rails are one piece, the wheelbase is only adjusted by link length and swapping damper mounts around. So I guess you could go longer without too much work, but even at the long 267mm wheelbase, the drive shafts are close to their limit |
01-22-2016, 09:19 AM | #24 |
Ok thank you. It's still a good product from what I've seen.
01-27-2016, 02:18 PM | #25 |
Got some more work done... Built the mounts for magnets (those will hold 3 kg, more than enough) Than, in order to get the body to the right height, I had to open up the rear deck a little. This provides enough space for the shock mounts, some diamond plate will cover them later on Wheelbase (247mm) and body height look alright now And there is enough clearance for the tires |
01-27-2016, 06:25 PM | #26 |
I wanna be Dave Join Date: Dec 2006 Location: Where the sheep run scared.
I like what you did with the body. Needs some nice tires |
01-28-2016, 03:25 AM | #27 |
| Re: Wranger YJ on MST CMX |
01-28-2016, 12:41 PM | #28 |
Next: getting a SCX10 bumper mounted... Drew a 3D file and got it printed at Shapeways At the same time, I designed a roll bar and I'm pretty happy with the result |
02-13-2016, 07:27 AM | #29 |
Had to redesign the bumper mount, but now it's the way I like it |
02-19-2016, 12:46 PM | #30 |
Don't like the battery mounted on top of the axle, so I got a new mount for my 3S lipos from Shapeways |
02-19-2016, 08:16 PM | #31 |
Quarry Creeper Join Date: Apr 2012 Location: Toronto
That is looking great!!!! Awesome work on the body. Looking forward to see how the chassis handles Sent from my MotoG3 using Tapatalk |
02-20-2016, 01:26 PM | #32 |
Body got some color and decals |
02-25-2016, 03:58 PM | #33 |
Rock Crawler Join Date: Jan 2014 Location: Granite Falls, WA
Any chance there will be a video of this rig in action? Would love to see that.
02-26-2016, 12:02 AM | #34 |
Newbie Join Date: Dec 2015 Location: Switzerland
What a beauty! Gesendet von iPhone mit Tapatalk |
03-10-2016, 07:14 AM | #35 |
Newbie Join Date: Oct 2014 Location: Greece
Any update on this rig? do the driveshafts and lockers hold up? I saw some heavy duty supposedly lockers on their site but it doesn't specify if it's metal or plastic.. It's probably plastic though. Also besides the 70mm shocks you think it would fit longer ones like 90mm or so? |
03-16-2016, 06:16 AM | #36 | |
| Re: Wranger YJ on MST CMX Quote:
I'm sure you could fit 80 or 90mm shocks, but you would have to mount them on the axle where the links go. | |
Wranger YJ on MST CMX - Similar Threads | ||||
Mst cmx | way6317 | Max Speed Technology CMX | 19 | 09-04-2016 06:51 AM |
Tamiya YJ/Wranger | DV8ion | 1.9 Scale Rigs | 14 | 10-15-2012 03:06 PM |
2.5l Wranger build | OSRC | 1.9 Scale Rigs | 14 | 04-11-2012 05:52 AM |
Wranger build | TAT76 | General Scale Talk | 14 | 10-20-2010 11:24 AM |
need help with Tamiya wranger YJ hardbody.... | STANG KILLA SS | 1.9 Scale Rigs | 14 | 08-29-2007 02:25 PM |
