Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Max Speed Technology CMX
Thread: New to cmx
Old 11-12-2017, 02:52 AM   #21
Default Re: New to cmx
Im still using stock links, i dunno what the fuss is about! For driveshafts i have cut down the extended male shaft cause its much stronger and used that for the rear axle, and for the front i have a cut down traxxas slash shaft, which popped onto the stock yoke. Its bulletproof now.
Mst cfx
Axial wraith
Axial yeti
8x venom creeper
Nzmaximus is offline   Reply With Quote
Old 11-21-2017, 03:33 PM   #22
snapon boy's Avatar
Here is what I have so far. Can't wait to drive it.
149 r/c worx/scalerfab/team brood.
snapon boy is offline   Reply With Quote
Old 11-21-2017, 05:18 PM   #23
Looks great, love the color combo!
OSRC is offline   Reply With Quote
Old 11-21-2017, 05:20 PM   #24
snapon boy's Avatar
Thank you. Im still not sure about the bumpers and sliders.
Old 11-23-2017, 08:27 PM   #25
snapon boy's Avatar
Here is what I have so far for a bumper. I wish scalerfab made bumpers for this model.
Old 12-03-2017, 01:10 AM   #26
You can use bumpers for Axial SCX10/10.2
Bowler is offline   Reply With Quote
Old 12-03-2017, 06:14 AM   #27
snapon boy's Avatar
Do you have any pictures
Old 12-03-2017, 05:32 PM   #28
Oppan Gangnam Style
chino63's Avatar
Here's what I've broken on my CMX.
Front, rear, extanded rear driveshafts.
Upgraded with Axial WB driveshafts.
Front CVD's.
These were advertised as 45 degrees but I think they redesigned them to increase strength as all the new kits show 40 degrees. I upgraded mine to modified ascender CVD'S which are substantially stronger but have a slightly reduced steering angle. I have not noticed it much while driving on tight technical trails.
Shocks leak (like all plastic bodied shocks) and will get green slime in the cartridge.
My kit came with bronze bushings so I did upgrade to a full ball bearing set. The stock bushings it came with will last for awhile if you can't afford it up front but like all kits, it is a highly recommended upgrade.
Somehow sand occasionally gets into the spur gear cover. This will get tossed.
Aside from those issues, this kit is 100% stock and performs awesome. It's pedictable handling has exceeded my expectations for a tiny tire truck with such a short wheelbase.
chino63 is offline   Reply With Quote
Old 12-04-2017, 08:23 PM   #29
snapon boy's Avatar
I changed all the stock electronics and the shafts to the wb shafts also. I have added bearings threw out. I had to make a few changes to get the beef patties to fit tho.
Old 12-09-2017, 01:08 PM   #30
snapon boy's Avatar
Any luck with torque twist? This little guy has it bad
Old 02-11-2018, 10:41 AM   #31
That’s odd, I’ve got three of these and none exhibit much if any torque steer at all.
alexleblanc is offline   Reply With Quote
New to cmx - Similar Threads
CMX Avalanche Zukiiholic Max Speed Technology CMX 6 10-25-2017 09:18 PM
MST CMX TJ take 2 03NCTJ Max Speed Technology CMX 34 07-11-2017 06:52 PM
Slipper for CMX ndecisive Max Speed Technology CMX 4 05-22-2017 05:59 PM
Mst cmx way6317 Max Speed Technology CMX 19 09-04-2016 06:51 AM
CMX axles? ThatGearHead Max Speed Technology CMX 1 04-03-2016 02:54 AM
