Go Back   RCCrawler Forums > Miscellaneous > Mega/Monster Trucks
Thread: Szczerba's Monster Truck Build on AR60's
Old 12-29-2012, 10:36 PM   #1
Default Szczerba's Monster Truck Build on AR60's
Here I go with another build!
I usually have over 100 pictures during my builds and this will probably be no different.
Chassis:
Rootar's wraith axle'd Monster Truck.
Rootar's Monster Truck 3/16" Tube Chassis built by Szczerba
Axial AX10 Skid
13.5" or so Wheelbase
Axles:
Vanquish Wraith CNC Machined Aluminum Axle Housings
HPI and Axial diff gears in Axial Diff Housings
Axial Lower Link Mounts
Vanquish Wraith Chubs C-Hub
Vanquish Wraith Steering Knuckles
Vanquish Titanium Tie Rod
ARB Diff Cover for Wraith
STRC Knuckles and C-Hubs
Axial universal's on all corners
Wraith "Dinky Link" S-Type (Front)
Wraith "Dinky Link" S-Type (Rear)
Transmission:
Vanquish Aluminum Transmission Housing
All Metal with Robinson 1 piece locker
BWD Heavy Duty Axial Motor Plate
MIP Driveshafts
32 pitch gears 54-60t
15-20t pinions
Shocks..
Undecided. Have some Longer HR's ready for mockup.
Links..
Lunsford Titanium Links 130mm - 140mm 120 unthreaded with revo rod ends (135mm total)
Electronics
Mamba Max Pro
Tekin Pro4@ 4000kv
Servos: Hitec 7950th and Hitec 5985tg
CC BEC PRO
3s Lipo
Wheels/Tires..
Tamiya Clod wheels
B&H Monster Truck Clod Tires Might have ordered the wrong tires! We'll see.
Body:
HPI Bounty Hunter or Proline 2007 Chevy Ext Cab.
Total Estimated Cost: $1,200
Szczerba is offline   Reply With Quote
Old 12-29-2012, 11:05 PM   #2
Default Re: Szczerba's Monster Truck Build on AR60's
This looks like it's gonna be good!
rangercat23 is offline   Reply With Quote
Old 12-29-2012, 11:07 PM   #3
That's the plan!
Chassis fab will get going next week. Most parts will be in by the end of next week as well.
Old 12-29-2012, 11:07 PM   #4
bout time...
ROLANDROCKSHOP is offline   Reply With Quote
Old 12-30-2012, 02:43 AM   #5
follow all your build threads,this one should be interesting one,forward to see what it will lokk in the end.heep up the good work
Kitty is offline   Reply With Quote
Old 12-30-2012, 08:41 AM   #6
Not enough motor.
Manning is offline   Reply With Quote
Old 12-30-2012, 11:20 AM   #7
if you can shrik your WB bit so you are 13'' or just under the truck looks more realistic
Real monsters have a bit of body past the tires
Looks like a good start though
william g is offline   Reply With Quote
Old 12-30-2012, 12:56 PM   #8
I see munched spider gears
frdtrkguy is offline   Reply With Quote
Old 12-30-2012, 01:04 PM   #9
Originally Posted by ROLANDROCKSHOP View Post
bout time...
Sorry, took me a couple days to gather up $1,200.
Thanks. The build pace will pick up in the next week or so.
Originally Posted by Manning View Post
Not enough motor.
Yea, zero right now.
Wheelbase is at 13.6" now cause I just happened to have some 120mm Lunsford Ti links laying around. My body choice will dictate the WB. Still undecided. Thanks for the tip.
If they are holding up in Rootar's Wraith'd Monster truck they should hold for me.
I have 4 sets of spares though!
Old 12-30-2012, 11:24 PM   #10
Love all the Wraith MTs popping up...great start cant wait to see wat you come up with....I think Im gonna have to do another one now lol
Kingclod27 is offline   Reply With Quote
Old 12-31-2012, 10:05 AM   #11
Thanks.
Rootar should be getting me his chassis templates soon.
I just placed the order for the Tekin Pro4 and Mamba Max Pro from Holmes Hobbies / Holmes Bikes
All other parts will be in sometime this week.
Old 12-31-2012, 10:41 AM   #12
I want to use a Pro4 on my next build...I had my chassis built around a 540 because I wasnt racing or anything but it still moves...the Pro4 would really wake it up...
Old 12-31-2012, 09:46 PM   #13
The pro4 fits any where any 540 can motor fits. Toss it in Bigfoot 18 and let her rip. chassis templates and a supply of tube should be to the szczerba shop by this Friday.
Rootar is offline   Reply With Quote
Old 01-04-2013, 09:26 PM   #14
Last of the parts will be coming in tomorrow.
Installed a Robinson Racing One Piece Trans gear, Vanquish Trans Case, Billet Works Designs Motor Plate and some Underdrive out back and HD Stock ratio gears up front.
Used a DLux 1/8" SLW spacer as a template and a 1/2" countersink bit to mod the wheels to fit SLW hubs.
Old 01-05-2013, 09:18 AM   #15
the picture looks like you have 2 different offsets front to rear on the wheels??
Old 01-05-2013, 09:35 AM   #16
Wow, Ol' Eagle Eye. Nice catch. Same SLW hubs on all 4 corners but I didn't have one of the wheels screwed all the way tight and the hub was not seated on the hex fully.
Front and rear is 15" wide right now with a 13.5 or so wheelbase.
Old 01-05-2013, 08:29 PM   #17
hows the chassis coming along?
Old 01-05-2013, 08:38 PM   #18
Slowly. AMA Supercross is on right now. And I smoked my Dremel.
These pieces just need a little bit more welding.
Old 01-05-2013, 09:52 PM   #19
good start!
Old 01-06-2013, 09:03 PM   #20
Little more progress today.
Szczerba's Monster Truck Build on AR60's - Similar Threads
Wraith monster truck build #3 william g Axial Wraith 15 02-23-2013 10:47 AM
Szczerba's Trophy Truck Build.. With Videos Szczerba Non Crawler RC's 110 07-18-2012 09:34 PM
looking to build a monster truck vigilant Kyosho Crawlers 10 04-09-2012 03:45 PM
Monster Truck build NickRummy Tamiya Clod Buster 34 11-26-2009 09:01 AM
Question about brushless system for monster truck build meancrawler Non Crawler RC's 1 05-07-2009 06:16 PM
