Go Back   RCCrawler Forums > Miscellaneous > Mega/Monster Trucks
Thread: Z-Maxx TXT MT Build
Old 10-27-2013, 10:39 AM   #1
Default Z-Maxx TXT MT Build
Working with a known RC Monster Truck chassis designer, I was able to get the CAD files for AL MT chassis he designed and had some buddies rework a couple things on it in CAD.
I changed the upper link locations to allow adjustability for various axles, re worked the cab a bit and cab location.
Works with Clod axles, wraith axles and TXT axles that I know of. I built one on wraith axles last summer.
I had three chassis cut for me to test and play around with.
Ended up going with delrin as chassis material, delrin chassis supports and AX10 AL skid.
Sent from my computer-phone.
Szczerba is offline   Reply With Quote
Old 10-27-2013, 10:43 AM   #2
Eddie at Crawler Innovations had some TXT axles with several goodies to go on them. He shipped me all the parts and away we go.
Eggressor 4:1. Old school, son.
TXTs
Link and servo mounts
Axle internal beef
Stock axle beef
Stock up top and Eggressor spool and revo gear below
Rut-row, dremel time.
Old 10-27-2013, 10:51 AM   #3
Default Re: Z-Maxx TXT MT Build
Originally Posted by JOETRUCKER80 View Post
That looks like it will be mean!
NICE!
Thanks. Here is the one I built up with wraith axles. I still have another chassis left that I will build up with clod axles, probably.
http://www.rccrawler.com/forum/axial...build-2-a.html
Old 10-27-2013, 01:13 PM   #4
Grinding the inside of the cases to get the larger 4:1 gears to fit.
Clearanced and new gear big and small gear installed.
Link/shock mounts
Lunsford and VP titanium links 13.75" wheelbase
Old 10-27-2013, 06:59 PM   #5
Mockup 3.5" shocks.
Wheelbase will be shorter just a touch.
Ford Body
Old 10-29-2013, 03:59 PM   #6
Tire&Foam Extraordinaire
Nova's Ark's Avatar
Sweet build thread bro! I will be sending many more parts this week for the build.
Nova's Ark is offline   Reply With Quote
Old 10-29-2013, 04:30 PM   #7
Yeah, son. These axles were cool to work on.
Old 10-30-2013, 06:11 PM   #8
Wow! Lucky you to find the Spools to do the 4:1 Mod! Those are a thing of the past for sure! I have a trick up my sleeve to make 4:1 axles.. and as soon as life slows down enough to give me a chance to try it out - I will. If it works - then I will definitely share the wealth
CraZySteve is offline   Reply With Quote
Old 10-30-2013, 06:17 PM   #9
I had never worked on the TXTs before this build. Eddie at Crawler Innovations just mailed me all the TXT goodies.
4:1 TXT axles? Or custom 4:1 axles?
Old 10-30-2013, 06:44 PM   #10
Sorry for not clarifying.. 4:1 TXT Axles
Old 11-02-2013, 02:03 PM   #11
New pile of parts from Crawler Innovations.
Correct Ti links, 3.5" Big Bores, hardware, driveshafts, nice trans with Scorpion BM 16 outrunner.
Old 11-02-2013, 03:10 PM   #12
Long pass through bolts for link/shock mounts.
Rear driveshaft setup
Front driveshaft with good clearances on trans/motor. Using Crawler Innovations 6mm outputs and BWD motor plate.
Rear
Motor clears skid
Side profile with new parts. I thought the driveshaft angles would but more sever but thankfully they are not.
Old 11-02-2013, 04:07 PM   #13
Mock up front and rear servos with mock up drag links.
Clod buster wheels and tires
Old 11-02-2013, 07:30 PM   #14
Nova's Ark's Avatar
That looks great Shane!! Gavin and I can't wait to drive it :-D
Sent from the lab @ the CI compound
Old 11-23-2013, 06:54 AM   #15
Wow awesome build! I'm now patiently waiting for a video.....patiently....
Exocaged is offline   Reply With Quote
Old 11-23-2013, 07:17 AM   #16
Thanks. Eddie will be getting this truck back next week. He'll be adding the electronics and mounting the Ford body. I am sure he'll have some video of it before too long.
Old 11-27-2013, 10:02 PM   #17
Gold Star Baby!
Arjeeprider's Avatar
Like the build!
Arjeeprider is offline   Reply With Quote
Old 01-01-2014, 07:48 PM   #18
Nova's Ark's Avatar
Well I had this truck back for a while now, thanks to Travis. It's already gone through a number of changes since it's arrival back. I installed electronics and got it running.
I installed hitec servos front and rear, castle creations ESC & Bec; futaba 4 PK receiver, traxxas Titan brushed motor; 3S lipo. Everything was fine for several battery packs until I finally stripped the front servo gears while trying a brushless motor out.
The truck was originally built around a pro line F6 50 super duty body, but I really didn't care for it. I had a Parma 41 Willys body laying around the shop that I was able to have painted. The body turned out so fantastic, that I've been reworking the entire truck to fit the body.
So all eight titanium links were replaced with shorter links and consequently reworking other issues with clearance around the servos and whatnot.
Mockup:
Painted body:
Test fit:
Old 01-01-2014, 07:52 PM   #19
Nova's Ark's Avatar
So while I have it torn apart to adjust the wheelbase, I'm also taking care of the scale accessories. Here's mockup of the motor & the Dinky RC fuel-cell that I painted with a freaky skins fuel cell sticker kit on some RC four-wheel-drive aluminum diamond plate.
Old 04-25-2014, 11:20 AM   #20
Any updates on this?
jdmerrill1240 is offline   Reply With Quote
Z-Maxx TXT MT Build - Similar Threads
maxx6 + txt maxx RôM Videos! 1 10-02-2008 04:03 PM
Txt to maxx shafts Magic Tamiya Txt-1 and Juggernaut 7 03-14-2005 02:52 PM
TXT to Maxx wheel adaptors. Ace Tamiya Txt-1 and Juggernaut 6 01-27-2005 09:05 PM
TXT or Maxx tranny? clodossal General Crawlers 2 12-29-2004 09:29 AM
E-Maxx, TXT-1 or Clod??? PoRiggity General Crawlers 25 04-20-2004 12:15 PM
