02-03-2014, 08:44 AM | #101 |
| Re: Harley's Mega Truck I don't have a set yet so I googled how long they are and found 145mm. Now after you talking about them being longer I looked it up again and find 165mm. Maybe there was more than one length?
02-03-2014, 08:48 AM | #102 |
| Re: Harley's Mega Truck That could be since there have been so many versions of the truck. Now I need to do some digging. I really like the long shock look but I can only stuff so much under the body before my ride height is going to get stupid.
02-03-2014, 08:57 AM | #103 |
| Re: Harley's Mega Truck Yeah ride height is a concern for me as well. I'm building a mega truck, not a mud truck. Since it is a race truck it has to corner. I am going to run front and rear sway bars, are you?
02-03-2014, 09:04 AM | #104 | |
| Re: Harley's Mega Truck Quote:
I would like to run sway bars, but I am concerned with the scale appearance. I would like to run some Axial style bars but I'm not sure if they are heavy enough for this truck. | |
02-03-2014, 09:22 AM | #105 |
So it looks like the E-Savage has 145mm shocks. #82055 Aluminum Threaded Shock Set (98-145mm/e-savage) The lower rod ends are really long so you could lose some length there with traxxas ends. The plastic E-Savage set is listed as 145 as well. http://www.horizonhobby.com/products...-esav-HPI82048 Last edited by Calderwood; 02-03-2014 at 09:26 AM. |
02-03-2014, 09:35 AM | #106 | |
Ok well that gives me something to search for. I'd like to find a nice looking set, that has some color coordination | |
02-04-2014, 06:36 PM | #107 |
RCC Addict Join Date: Mar 2011 Location: Way out there!
What foam are you using in these wheels? I glued my front rims together before the tire (OOPS brain fart) and have cut off my access to put foams in. I am hoping the tire will be stiff enough to work anyway.
02-04-2014, 06:39 PM | #108 |
| Re: Harley's Mega Truck I am having some custom foams made. I think foams are going to be as important as the tire itself. A stiff foam will be a must in my opinion.
02-04-2014, 06:41 PM | #109 |
02-04-2014, 07:02 PM | #110 |
| Re: Harley's Mega Truck I'm hoping to do a set of closed cell foams. The waterproof feature will be extremely important. The OD of the tires is very similar to some of the popular 2.2 tires so modifying a set of his existing Deuces Wild foams will likely be possible.
02-05-2014, 08:51 PM | #111 |
This truck definitely needs something to fill that empty pickup bed. I found the solution. I also welded on all of my shock mounts. Now I have to wait for the shocks to show up. I will extended the wheelbase when they arrive. |
02-05-2014, 08:58 PM | #112 |
Coming along. Does supershafty still (or did) make the 8mm AX10 outputs? After just working with some twin force axles that axle pinion output shaft is large! You may have already mentioned that. |
02-05-2014, 08:59 PM | #113 |
| Re: Harley's Mega Truck They sure do! I have them sitting right here ready to go in my Orange splatter case! |
02-05-2014, 09:02 PM | #114 |
| Re: Harley's Mega Truck |
02-06-2014, 05:48 PM | #115 | |
Rock Crawler Join Date: Apr 2004 Location: Not where I belong.
Fasten it to the inside of the lower link, run towards the skidplate and make a bend to run across skidplate and follow other lower link. It would be kinda tricky to mount it to the skidplate in a way that cycles with the suspension, but could be hidden better than the axial style. | |
02-06-2014, 05:52 PM | #116 | |
02-07-2014, 04:40 AM | #117 | |
I have used a bent "U" shaped coat hanger zip tied to the lower links. It was temporary but worked. | |
02-08-2014, 04:58 PM | #118 |
First thing I did today was assemble my transmission with the Super Shafty 8mm outputs, my Super Shafty/Harley/Vanquish case, Beefy Top Shaft, and Robinson Stage 3 slipper. Today I welded in my skid plate as well as a kicker in the front of the skid to keep from digging in when in the mud at speed. |
03-04-2014, 06:53 AM | #119 | |
Newbie Join Date: Oct 2013 Location: waseca
Sent from my M470BSA using Tapatalk | |
03-04-2014, 07:35 AM | #120 |
Harley's Mega Truck - Similar Threads | ||||
looking for mega cab dodge or crew cab truck. | rockslide710 | Paint and Body | 0 | 01-22-2012 05:23 PM |
Dodge mega cab prerunner/chase truck | Wicked_Jester | 1.9 Scale Rigs | 27 | 02-14-2010 11:46 AM |
Harley's 2.2 Blazer Trail Truck | Harley | 2.2 Scale Rigs | 21 | 01-06-2008 07:37 PM |
