Go Back   RCCrawler Forums > Miscellaneous > Mega/Monster Trucks
Thread: Junkyard Build Using SCX10 Axles, ECX Frame, And Lunchbox Body
Old 01-16-2020, 08:31 AM   #1
Default Junkyard Build Using SCX10 Axles, ECX Frame, And Lunchbox Body
I have always liked the Tamiya Lunchbox but as an RC is was not great. I am building a 4WD Lunchbox around a Parma lexan body.
4WD Lunchbox by captaininsano1000, on Flickr
12MPG is offline   Reply With Quote
Old 01-16-2020, 08:36 AM   #2
Default Re: Junkyard Build Using SCX10 Axles, ECX Frame, And Lunchbox Body
I am using an ECX Barrage frame because it fit the short wheelbase of the Lunchbox better than anything else I could find. I purchased a drop subframe from Aliexpress but it hasn't arrived yet.
https://www.aliexpress.com/item/3288...40b94c4dKMPB1W
ECX Frame by captaininsano1000, on Flickr
It is going to ride on these 30 year old Proline Mashers.
IMG_9481 by captaininsano1000, on Flickr
Old 01-16-2020, 08:43 AM   #3
I pulled a set of axles off my SCX10 and swapped out the lockers for open diffs. The spider gears were removed from an HPI RS4 MT that I had wrecked a few years ago. The opens diffs seem to turn pretty smooth. The original dog bones were in rough shape so more aliexpress parts went in.
IMG_9482 by captaininsano1000, on Flickr
Old 01-18-2020, 09:09 AM   #4
Cool kitbash build, my man!
durok is offline   Reply With Quote
Old 01-29-2020, 02:27 PM   #5
Natedog's Avatar
Agreed, pretty cool!
Old 01-30-2020, 10:48 AM   #6
I didn't know there was term for this.
Old 01-30-2020, 10:49 AM   #7
My chassis drops arrived and I re-drilled them for the ECX Barrage plate.
Lunchox 4X4 (1) by captaininsano1000, on Flickr
Old 01-30-2020, 10:51 AM   #8
Getting the Chinese SCX gearbox to fit is going to be tough. I would love to have access to an HPI Wheeling King transmission but if I spend $60 in parts, that defeats the purpose of my junkyard build. I might clock the transmission to center the output shafts and build a plate to mount it. The ECX Barrage frame rails do not flair out in the middle like the SCX10 rails do.
Lunchox 4X4 (3) by captaininsano1000, on Flickr
Old 02-03-2020, 08:55 AM   #9
Default FAILURE! I can't make the drive shafts work.
I just could not make the drive shafts work. There just wasn't enough space. I am going with Plan B. I am going to run two Brushless 380 motors.
Failure by captaininsano1000, on Flickr
Old 02-04-2020, 08:36 AM   #10
All four upper links were made from one Axial link.
Links by captaininsano1000, on Flickr
The shocks used here don't have enough travel for my final vision but they'll work fine for mock up. I will eventually have two identical brushless motors mounted.
Lunchbox Chassis by captaininsano1000, on Flickr
Old 02-05-2020, 11:11 AM   #11
i like plan b. may i suggest plan c? a single outrunner from eflite. no trans.
this is better than my mini monster.
Sent from my LGMP260 using Tapatalk
CM9000 is offline   Reply With Quote
Old 02-06-2020, 01:00 PM   #12
I did not know that was an option until you mentioned it. If plan B fails, I'll give that a try. I did get the truck to move under its own power today in front wheel drive with the brushed motor and a 20 AMP ESC. It moved fine on flatground but stalled easily when I tried to climb some things. I think I'll be in fine shape with the two brushless motors running.
Old 02-06-2020, 01:14 PM   #13
Lunchbox4WD by captaininsano1000, on Flickr
4X4 Lunchbox (2) by captaininsano1000, on Flickr4X4 Lunchbox (1) by captaininsano1000, on Flickr
4WD Lunchbox (1) by captaininsano1000, on Flickr
Old 02-06-2020, 08:52 PM   #14
man thats bad ass.
Old 02-13-2020, 10:34 AM   #15
The Coronavirus is delaying my Chinese build supplies. I am waiting on another gearbox and a couple of ESCs.
Old 02-26-2020, 12:15 PM   #16
I used part of the tub from the original Tamiya Lunchbox.
Rule 134 in the Lunchbox Racing Association rule book strictly states that trucks running in the modified class must retain 25% of the original chassis(I made this up, there is no Lunchbox Racing Association but there should be!)
Lunchbox 4WD (1) by captaininsano1000, on Flickr
I really just liked how well the 2 ESCs fit in the existing receiver box. I figured it would also keep mud out of the inside.
Lunchbox 4WD (2) by captaininsano1000, on Flickr
Old 03-16-2020, 10:11 AM   #17
I bought these shocks from Aliexpress. They are great quality for the price.
https://www.aliexpress.com/item/3301...27424c4dXgbGyX
IMG_0437 by captaininsano1000, on Flickr
Old 05-28-2020, 06:27 PM   #18
How is the build coming along?
Catbox is offline   Reply With Quote
Old 06-22-2020, 11:20 AM   #19
j0e
Originally Posted by 12MPG View Post
...Rule 134 in the Lunchbox Racing Association rule book strictly states that trucks running in the modified class must retain 25% of the original chassis(I made this up, there is no Lunchbox Racing Association but there should be!)...
hahaha!
I hope this build is still progressing.
lookin' good so far.
j0e is offline   Reply With Quote
Old 07-17-2020, 07:01 PM   #20
Twp
Wow that Lunchbox body brings back some memories. That was my first real RC. Probably in the mid 80s.
Twp is offline   Reply With Quote
Tags
4wd lunchbox, lunchbox, lunchbox rc crawler
Junkyard Build Using SCX10 Axles, ECX Frame, And Lunchbox Body - Similar Threads
Jakezilla’s Junkyard fakeCX10 build. Injora / Austar 313mm Frame Jakezilla Axial SCX10 II 14 03-22-2020 09:21 AM
Who can build me a truggy frame that will bolt to an scx10 or fulll frame? mtgrizzlymn Newbie General 4 07-04-2012 11:14 AM
