01-06-2017, 09:26 AM | #1 |
I wanna be Dave Join Date: May 2010 Location: The east coast
| Waterproof electronics recommendations
Been doing some research but figured I'd open the floor for some people who have experience. Starting to build a mud truck of sorts. Just something I can run in the yard when it is wet or muddy. Not heavy bashing or mud pit runs. It will be based off ar60 axles with 2.2 mud basher tires. Will be making a toyzuki style tranny/transfer case. My plan is to keep most of the electronics up high to reduce the amount of time they spend in the mud/water. Will have a deck that extends out to the body to provide a limited seal against splashes. I'm not looking to break the bank. Figure around $100 for motor/esc and $75 for a servo. I do want brushless for the motor/esc. If there is a sensored brushless that fits that would be an option. I'm also not loyal to any specific brands. I've ran castle, novak, tekin, axial, etc. with good/bad stories in most cases. All input is welcome. |
01-06-2017, 09:53 AM | #2 |
RCC Addict Join Date: Aug 2008 Location: Paulina
| Re: Waterproof electronics recommendations
The Castle Sidewinder and 3800kv motor would likely be a good choice.
01-06-2017, 10:16 AM | #3 |
2s or 3s ? Hang up and Drive |
01-06-2017, 01:01 PM | #4 |
| Re: Waterproof electronics recommendations |
01-06-2017, 01:03 PM | #5 |
01-06-2017, 01:32 PM | #6 |
01-06-2017, 06:03 PM | #7 |
HobbyWing or Kinexsis 4000kV combo. A 3000kV combo is also available. 1/10 4-Pole 4000Kv ESC/Motor Combo | HorizonHobby |
01-06-2017, 08:01 PM | #8 | |
| Re: Waterproof electronics recommendations Quote:
01-06-2017, 08:37 PM | #9 |
| Re: Waterproof electronics recommendations No personal experience with that. But the ESC looks like a HobbyWing ESC that I have in mine. I have no complaints. Plus, it's a Horizon product so it will most likely be good. If not they have the best customer service in the industry.
01-07-2017, 09:16 AM | #10 | |
For a servo I think the xpert 7000 series looks promising. Not looking to start a which is better discussion but does anyone have experience with it? | |
01-07-2017, 10:05 AM | #11 | |
Get an ESC with at least 80A and a 4-pole motor between 3500 kV and 4000kV and you should be fine. | |
01-14-2017, 07:08 AM | #12 |
Just realized the tranny I plan on running uses a mod1 spur gear, so the motor pinions are all 5mm shafts. That limits the options for me. I saw this in my search: 3674 2250KV 4P Sensorless Brushless Motor + 120A Brushless Splash-Proof Electronic Speed Controller with 5.7V/8A Switch Mode BEC for 1/8 RC Car Truck | Alex NLD Specs all seem decent except for the kv. Is that going to be too low in comparison to my target 3500kv rating? |
01-14-2017, 10:20 AM | #13 |
Actually, I'm thinking this might be a good one. More than I was looking to spend but should be solid. http://www.ebay.com/itm/Hobbywing-EZ...MAAOSw-0xYb32j |
01-15-2017, 08:28 AM | #14 |
Rock Stacker Join Date: May 2015 Location: CF
I'm selling my new SC8 hobbywing combo with 3400kV motor and programmer. It's got a 3mm shaft but has an adapter for 5mm mod 1 pinions. Cheaper than what you linked to. Sent from my SM-G935V using Tapatalk Last edited by YXLER; 01-15-2017 at 08:34 AM. |
01-16-2017, 07:43 AM | #15 | |
01-16-2017, 05:14 PM | #16 |
Waterproof electronics recommendations - Similar Threads | ||||
Electronics Recommendations | hulmt | Electronics | 3 | 05-09-2014 06:28 PM |
Got my vaterra vol. need recommendations on upgraded electronics | yeezus | Vaterra Twin Hammers | 14 | 11-05-2013 07:13 PM |
Electronics recommendations for an xr10 | Dezertdirt | Newbie General | 57 | 08-30-2013 06:49 AM |
Twin Hammers Electronics Recommendations? | alexchen86 | Vaterra Twin Hammers | 5 | 05-07-2013 08:42 AM |
lowering the body and the electronics getting the electronics in a waterproof box | m1009cucv | Axial SCX-10 | 15 | 10-01-2011 07:45 PM |
