Go Back   RCCrawler Forums > Miscellaneous > Mega/Monster Trucks
Thread: Son uva Digger smt10
Old 08-28-2017, 07:15 PM   #1
Default Son uva Digger smt10
This is my first axial smt10 wanted to do something special since I've always been a son uva digger fan for year an a close friend of Ryan. Started out as a joke when me an my buddy left hobbytown with 1200 worth of goodies to where is is now. Note I only bought the truck he bought everything else lol. Took the MaxD truck out the box played with it for 5mins till it was time to take it all apart.
-Build part list-
-Son uva Digger body from Drive Rc
-Axial HEAVY DUTY BEVEL GEAR SET 43T/13T
-Hot Racing Black internal spring air shock 100mm
-Hot Racing Remote reservoir IS Damper 100mm
-Incision SCX10 Transmission Outputs
-Incision SMT10 Trailing Arm Delete Link Kit
-Incision Spool / Locker
-Incision Yeti 1/4 Stainless Steel Rear Upper Suspension Link Kit
-Racers Edge SCX10 Aluminum Center Transmission Case, Silver
-Team KNK Axial SMT10 Stainless Hardware Kit
-Vanquish Products Currie Antirock Yeti Sway Bar V2 Black Anodized
-Axial Steel Spur Gear 32P 56T
-Castle Creations 1/10 SV3 Sidewinder WP ESC 5mm 1410-3800
-SSD RC HD Steel Transmission Gear Set
-AXIAL RACING AR60 OCP Universal Axle Set FRONTSHAFTS
-Boom Racing AxiaLock-outs
-SMT10 AR60 Aluminum Rear Axle LockCarrier
-Boom Racing Axial Wraith & SMT10 AR60 Aluminum C Hub Carrier
-Boom Racing Axial Wraith AR60 Aluminum HD Steering knuckle
Currently waiting for the rest of my parts to come in to build the trans an get this thing rolling
Sent from my XT1650 using Tapatalk
gotnoodoe is offline   Reply With Quote
Old 08-30-2017, 12:32 PM   #2
Moderator
JatoTheRipper's Avatar
Default Re: Son uva Digger smt10
This is an awesome frickin' start!
Old 08-30-2017, 03:12 PM   #3
Finally got my trans parts in an sadly couldn't get the parts to work together for some odd reason. SSD trans gears an the incision outputs didn't want to work together. So put the stock outputs in it. Guess once these break I'll have a new one piece bottom gear in for it
Old 10-02-2017, 04:21 AM   #4
I had the same problem with ssd gears and the vanquish outputs. If you switch to a Robinson racing bottom gear or if you can get rid of the ring on the inside of the gear which prevents the outdrive to go in all the way
c0bra is offline   Reply With Quote
