08-05-2018, 03:34 AM | #21 |
Quarry Creeper Join Date: Nov 2017 Location: Ulaanbaatar
| Re: Soze's SMT10 fleet.
Very helpful build thread! Thank you.
08-05-2018, 11:26 AM | #22 |
RCC Addict Join Date: Feb 2016 Location: Princeton, North Carolina, USA
RCAWD Really well done build thread here, buddy! Guess all those 16-hour work days didn't completely finish you off. I wonder how well that DS3218 servo is going to work for you with those beefy tires though. I ate one on a Bomber in less than three hours. Hope your experience is more positive. |
08-05-2018, 11:37 AM | #23 | |
| Re: Soze's SMT10 fleet. Quote:
Friday was my last day at that employer.... and they had me work up until the evening on the last day.... definitely squeezed every last bit of juice they could out of me. I start at a new employer in 2 weeks. Unfortunately it's also a consulting company, but it's a larger publicly traded one and stated they don't really do fixed-bid projects and mostly bill projects as time & materials, so hopefully better. Eventually I'll head back into the corporate world though. Would be nice to leave thoughts of work behind after 5pm. | |
08-05-2018, 11:46 AM | #24 | |
Congratulations on reclaiming your life! I'll celebrate vicariously. I work with several consultants who have been offered full hire with the company and refused to avoid the very trap you just escaped from. | |
08-05-2018, 12:06 PM | #25 | |
This smaller shop offered 100% work from home and no 99% no travel. Little did I know... work from home meant chained to desk at home. I had 3 other co-workers here from previous employers that joined me at this one. They all left. One of them had health issues that started after joining... and miraculously got better after he had enough and quit. A lot of stress and hours. Last edited by soze; 08-05-2018 at 12:10 PM. | |
08-05-2018, 12:52 PM | #26 | |
Now you have two weeks to focus on this cool build...and the next one! | |
08-07-2018, 02:42 PM | #27 |
I wanna be Dave Join Date: Dec 2016 Location: san diego
Grave Digger upgrade looking good, and nearly bulletproof! how do those axle shafts hold up against a good cartwheel? lol asking for a friend... my yeti AR60 had bent shafts and i replaced the whole thing with an SSD nylon D60. included the shafts and the whole thing was cheaper than any "strong" AR60 shaft. the axles and shock placement are the only things i would have to change if i got one of these. they just don't look accurate enough. sure they probably perform GREAT but i think i am turning into a scale snob lol cant wait to see whats next and your upgrades for MAX D! Last edited by Shinchu; 08-08-2018 at 09:08 AM. Reason: "grade digger" stupid auto-correct... |
08-07-2018, 04:34 PM | #28 | |
08-08-2018, 09:20 AM | #29 |
on my first ship i was worked until 1700 on my last day there. my LPO's coveralls were hanging in berthing when i finally left. his collar smelled funny after that... ;) anyway back on topic... check your nuts! Monster Truck Madness – Hold On To Your Nuts « Big Squid RC – RC Car and Truck News, Reviews, Videos, and More! |
08-08-2018, 11:45 AM | #30 | |
Hanging onto my nuts. | |
08-10-2018, 11:58 AM | #31 |
| Re: Soze's SMT10 fleet. Max-D Upgrade Part 1: Transmission Gears, Transmission housing, Spur Gear, and Motor Aluminum Transmission Case SSD RC Steel Transmission Gears for SCX10/Wraith/SMT10 Xtra Speed HD Steel Spur Gear 56T/15T Hobbywing Quicrun 10BL60 Brushless unsensored ESC HobbyStar 4-Pole 3500kv Brushless Waterproof Motor Starting the Max-D upgrade. Very similar to the Grave Digger with a few different parts. First thing that needs to be taken care of are the transmission gears and housing. This was a surprise... I've run this truck 2x.. 2! All on stock 27t brushed motor driving around the driveway. You think bringing this up to Axial will achieve anything? SSD HD Gears going in... Aluminum Transmission Housing New SSD HD Gears in aluminum transmission housing (wiped away excess grease after taking picture) Xtra Speed 56T Steel Spur gear going in Xtra Speed Spur mounted on All meshed up Using a Hobbywing Quicrun 10BL60 Brushless Esc HobbyStar 3500kv 4-pole Waterproof Brushless Motor Powerplant/powertrain all mounted up |
08-13-2018, 12:37 PM | #32 |
| Re: Soze's SMT10 fleet. Max-D Upgrade Part 2 - Axles Onward to part 2 of the Max-D upgrade.... got the following going in. MIP X-Duty C-Drive Steel Drive Shafts for Axial SMT10 (MIP18190) Axial Heavy Duty Locker (AX30500) Xtra Speed Stainless Steel Axle Tubes Boom Racing Axial Wraith HD Steel Rear Axle Shafts For AR60 Axle Boom Racing Axial Yeti Heavy Duty Bevel Helical Gear Set - 38T/13T SSD RC HD D60 Knuckles Vanquish Products Aluminum Wraith/Yeti Clamping Lockout Took out the stock rear diff gear setup. Put that Axial Locker in Boom Racing HD Helical Gear Set put in Time for the Xtra Speed Axle Tubes Axle tubes are in Boom Racing HD Axle shaft for tubes Vanquish AR60 Rear lockouts Rear axle is done Starting the front axle Xtra Speed Axle tubes going into the front axle The tubes are all in SSD HD60 Knuckles Knuckles are on MIP X-Duty C-Drive kit for SMT10 Lower half of the MIP Shafts put on the axles. Part 2 done. |
08-13-2018, 12:58 PM | #33 |
| Re: Soze's SMT10 fleet. Max-D Upgrade Part 3 - Suspension, Links, Servo Getting to the stability upgrades for the Max-D to handle the extra power and weight. Axial RR10 Bomber Rear Sway bar AX31331 (for use in SMT10 front axle) Axial Lower Link Plates for Bomber/Yeti/SMT10 (AX31245) SSD RC Titanium Upper Links SSD RC Titanium Steering Links Vanquish Products AR60 Axle Servo Mount SSD Titanium Upper links SSD upper links and Yeti lower link plates installed Top half of the MIP shaft installed and connected in the rear Vanquish Servo mount went on Using Axial Bomber Rear Sway bar as a front sway bar on the SMT10 Front sway bar installed Suspension all mounted up DS3218 Servo mounted on. Hopefully it holds up. SSD Titanium Steering links Decided to use the stock servo horn instead of the Boom Racing aluminum one. Front axle MIP shaft connected and all mounted up. |
08-13-2018, 01:07 PM | #34 |
| Re: Soze's SMT10 fleet. Max-D Upgrade Part 4 - Wheels and Tires Getting to the final part of the upgrades.... JConcepts Tribute Wheels 2.6x3.6 (Silver) JConcepts Firestorm Tires (Blue Compound) JConcepts Tribute Wheels and Firestorm Tires. Mounted and glued ahead of time. The final look Last edited by soze; 08-29-2018 at 04:20 PM. |
08-13-2018, 01:19 PM | #35 |
Rock Crawler Join Date: Apr 2017 Location: Northeast PA
I'm beginning to think that self-machining gearbox is an intentional design feature because I've seen it happen to so many different people (including myself). It's disappointing because you know Axial really could've done better by this time in the production run if they cared at all. Anyway, great build thread as usual. I'm sure yours will be fun and reliable with all those upgrades! |
08-13-2018, 02:03 PM | #36 |
Killer! I'd love to see the brushless setup that'd tear all that beef out anytime soon! |
08-29-2018, 03:22 PM | #37 |
i just noticed we have the same wedding band lol titanium from Daniel's lol cant beat the price though!!! builds are looking rad! when do we get some action pics/vid? |
08-29-2018, 04:19 PM | #38 |
| Re: Soze's SMT10 fleet. |
08-29-2018, 07:16 PM | #39 |
11-28-2018, 08:22 PM | #40 |
Quarry Creeper Join Date: Feb 2018 Location: Melbourne Australia
Love the trucks!! hope your having mad fun |
Soze's SMT10 fleet. - Similar Threads | ||||
Soze's GMade Sawback 4LS | soze | G-Made Sawback | 23 | 12-31-2021 12:59 PM |
Soze's HoBao DC1 Kit Build | soze | 1.9 Scale Rigs | 103 | 09-10-2021 12:04 PM |
Soze's GMADE GOM GR01 Build | soze | G-Made Crawlers | 69 | 08-20-2021 12:45 AM |
Soze's MST CFX-W Build | soze | Max Speed Technology CFX | 90 | 01-31-2019 01:02 AM |
Soze's Axial Yeti Kit Progress tracker. | soze | Axial Yeti | 31 | 03-09-2018 12:22 AM |
