Go Back   RCCrawler Forums > Miscellaneous > Mega/Monster Trucks
Thread: CEN RC Monster Truck Series...thoughts?
Old 09-14-2019, 04:22 PM   #41
Default Re: CEN RC Monster Truck Series...thoughts?
I know it's fun right? They list it as having stiff racing suspension. I noticed another thing today. The battery holder has different adjustments so it's not all the way in the back. I moved it...much better doesn't wheelie as easy. More stable on jumps too.
Sent from my SM-G965U using Tapatalk
FormallySkullking is offline   Reply With Quote
Old 09-29-2019, 11:00 PM   #42
Had a few packs through it in different surroundings. It’s solid. Even my rather clumsy pal couldn’t break it. It rolled, flipped landed crooked several times.. apart from some scuffing of the body, not a scratch.
Motor, gearing and ESC are perfectly chosen. Even with ambient temps way above 35°C it just kept on going, pack after pack, even in (short) grass.. usually that strains every bit of motor and electronics to the max. I do not know if changing the gears around for ‘speed’ will heat-up everything too much. Not going to try. The current speed and power with the stock 15t 550 is plenty for me. ( You listening Axial?.. squeeze a 15t 550 in Your SMT10 re-release, not some wheezy 27t. Design a new skid plate to make it fit.. I don’t care, as long as there’s a stout 550 in it... oh, and metal gearbox gears, because Your plastic butter-gears will disintegrate with a 550)
Still too harshly sprung for my taste, though. Going to experiment a bit with springs and oil. By the by, shocks didn’t leak a drop.. Not bad for an RTR.
AFA size goes, it’s a perfect intermediate between a Wheely King, and a TXT ( got both) with the added bonus of lighter weight than the TXT ( = no mega power required to make it scoot about quite satisfactory) and better gears than the Wheely King. CEN did good imho.
Jay-Em is offline   Reply With Quote
Old 09-29-2019, 11:14 PM   #43
Originally Posted by FormallySkullking View Post
It's the same size as a scx10ii with smaller style axles. Problem with making a scx10ii into a MT is you will only have locked diffs.
Locked diffs in this scx10 based build. Fun as hell! Had rear steer though.
Sent from my LGMP260 using Tapatalk
CM9000 is offline   Reply With Quote
Old 10-01-2019, 07:05 AM   #44
I’m trying to decide between one of these CEN trucks or a Clodbuster. Anyone have any recommendations one way or the other?
I do like the setup on the CEN but am worried about getting parts mostly.
SlagMan is offline   Reply With Quote
Old 10-01-2019, 07:19 AM   #45
Clodbuster
ROWDY RACING is offline   Reply With Quote
Old 10-01-2019, 07:50 AM   #46
They are 2 totally rigs, set ups, etc. So far the parts for the Cen are easy to get. I haven't needed anything but the diff gears.
Old 10-01-2019, 10:44 AM   #47
Thanks. I’ll probably get both eventually but wanted to hear about the CEN first.
Old 10-01-2019, 11:33 AM   #48
I have both and very different from each other indeed.
Old 10-01-2019, 02:19 PM   #49
I ordered a Clod. Will be keeping an eye on the CEN for a future truck!
Thanks for your help.
Old 10-10-2019, 09:46 PM   #50
You’ll be happy. I got both. And, indeed, different beasties.
The Clod is rather big, compared with the CEN, mainly through the wheels. Which is fun, but also rather great is the simple fact that parts and tuning parts are nòt a problem whatsoever.
Though, truth be told, the speed of a stock Clod, compared with the CEN is not that impressive, and to really get some scoot it’ll need at least 2 x 19t brushed motors. Also, big 550motors won’t fit, unless You replace all swingarms.
Oh, and get at least a 20kg servo, stronger if You can afford it, otherwise it turns like a battlecruiser.
Old 10-11-2019, 09:05 AM   #51
I built my Clod last weekend. Used a 20kg red. Didn’t turn worth a darn. I ended up using one of the big cross servo horns that came with the servo. Now it turns great, at least considering it still has stock rods.
I like it for what it is and am quite happy.
Once CEN becomes more common or at least it appears parts are readily available I’ll get one.
Old 10-17-2019, 12:55 PM   #52
Mine is for sale, I caught the rally/drift bug
CEN RC Monster Truck Series...thoughts? - Similar Threads
Showtime solid axle monster truck series. ROWDY RACING Virginia 2 07-20-2016 05:10 AM
505RC Monster Truck Race Series - Sponsored by CowRC Team CowRC Non Crawler RC's 0 12-31-2013 09:59 AM
505 Monster Truck Series - November 9th by 505RC Team CowRC Non Crawler RC's 0 11-24-2013 11:01 PM
New 505RC Monster Truck Series - Presented by CowRC! Team CowRC Non Crawler RC's 0 06-24-2013 06:11 AM
