axle It appears that most of the chassis kits are engineered around the AR60 OCP axles. So other than Axial who make a decent compatible complete front and rear axles? I've found some Asian versions on Ebay but after reading reviews they don't seem to rate well. |
Re: axle I'm thinking about buying two AR60 OCP axle kits and making a 4 x 4 x 4. Axial sells the kits: Axial Racing - AR60 OCP Front Axle Set (Complete) |
Re: axle You can also buy a F/R set from CPE, outfit them as you wish. Also to add to your other thread they have some pretty slick chassis’s as well Crawford Performance Engineering |
Re: axle freestyle rc would be my suggestion there really well made and use traxxas e max internals so are designed tough and east to get parts for but they are a little expensive |
Re: axle What kind of power are you going to be putting in the truck? |
Re: axle Quote:
And I have a HW SCT pro combo on my bench too. |
Re: axle Quote:
I looked at RC4WD as well and they don't have any Digger axles in stock. |
Re: axle I'm having a hard time accepting that custom housings with plastic Revo shafts inside is the answer. I have a T-maxx, and those shafts wear quickly, break easily, and you can't keep the through pins tight because the yokes are plastic. What am I missing hear? I feel the MT community deserves a decent set of solid axles with 1/8 guts. |
Re: axle Quote:
Re: axle MIP makes shafts, but I'm not sure if they can be shortened easily enough to work on our application. |
Re: axle Quote:
Re: axle Ya Axial really dripped the ball by leaving the AR60s the same. I ended up with a Kyosho Mad Crusher and its axles are like 3X thicker. Its a great truck. |
Re: axle On one hand I really don't like kyosho, but on the other I think they are the only ones making a solid axle with true 1/8 guts. I've seen split housings with them too though, so there is still plenty of room for improvement. |
Re: axle i agree with jato the metal ar60 with big bearings hold up realy well ive run the castle 15151/8th scale motor on 6s and the novak hd8 1/8 scale motor with a momba esc for years and dident break anything the biggest issue is wheel nuts coming loose and hex pins shearing both easy fixes |
