06-22-2020, 10:24 AM | #1 |
Newbie Join Date: Jun 2020 Location: Canada
| SMT10 drive shaft - 4Link cclearence?
In an attempt to get the truck to sit as low as possible i have noticed a clearence issue with the upper link and the driveshaft before the shocks bottom out. Is there any way to resolve this? Currently stock links and driveshaft. |
07-05-2020, 07:04 PM | #2 |
| Re: SMT10 drive shaft - 4Link cclearence?
Make your own custom bent upper links. I prefer using 3/16" stainless rod with the ends turned down a bit threaded to 4mm and Revo rod ends installed. There are many other methods to building links as well.
07-06-2020, 06:49 AM | #3 |
I did get some Crawford Performance links but the plastic rod ends are wear and i have broken 2 already on the lower links. I will check out Revo for sure.
07-06-2020, 07:23 PM | #4 |
It's still possible to break the Revo rod ends when used as lowers, but they are an acceptable fuse to me as they dont let go easily and are cheap to replace. I've never broke them when used as uppers, just slowly worn them out and I eventually replace them due to slop. RPM makes a "Revo" style rod end that is a little stronger than the Traxxas version, but they dont come with the pivot balls, and the balls are slightly different size than the Axial variants, so you gotta buy the Traxxas rod ends to be able to use the RPM version.
07-07-2020, 10:41 AM | #5 |
Newbie Join Date: Apr 2008 Location: Wilhelmshaven/ Germany
It is very simple, turn the uppers 180° I had the same probs. |
07-07-2020, 12:20 PM | #6 |
| Re: SMT10 drive shaft - 4Link cclearence? |
07-07-2020, 01:11 PM | #7 | |
I joined the Band! Join Date: May 2020 Location: US
| Re: SMT10 drive shaft - 4Link cclearence? Quote:
07-08-2020, 07:35 AM | #8 |
If i switched to metal Rod ends what is the next likely weak point? Diff Housing?
SMT10 drive shaft - 4Link cclearence? - Similar Threads | ||||
New drive shafts for SMT10 | chino | Mega/Monster Trucks | 26 | 10-19-2016 03:49 PM |
best way to join a rwvo drive shaft to the output shaft on the axle | TRAV | Kyosho Crawlers | 12 | 01-29-2012 07:37 PM |
***MIP C-Drive Drive shaft for the AX10...GIVEAWAY*** | Rockpiledriver | RCP Crawlers | 153 | 07-01-2008 11:18 AM |
