07-08-2020, 10:40 AM | #1 |
Newbie Join Date: Jul 2020 Location: North Dakota
| Cheap/Easy SMT 10 stock lower link fix/ reinforcement
So with parts and spares being backordered everywhere I got creative and found a way to turn garbage into budget fix / reinforcement for stock SMT 10 lower links. I had some broken traxxas Stampede 2wd fixed length camber links in my hardware bin ( no judgement for being a hoarder keeping busted parts around ) So, you know those empty hollow spaces left on SMT10 lower links ( in whichever space the shock isn’t mounted )? Well these are a potential place to bend or kink under side load in a bad landing. Well a piece of this broken TrAxxas part cut to length wedges in there perfectly and gussets this hollow space easily. I’m sure if you don’t have broken Stampede links laying around another piece of scrap plastic or even some of that stryrene I-Beam that scratch builders use would also work. Sent from my iPhone using Tapatalk Last edited by Dakratfink; 07-08-2020 at 10:43 AM. |
07-08-2020, 12:35 PM | #2 |
Newbie Join Date: Jun 2020 Location: Canada
| Re: Cheap/Easy SMT 10 stock lower link fix/ reinforcement
Instructions on the SMT10 Builders Kit say to put a spare plastic ball end in there. I didnt do that at first and they bent almost immediately. definitely needs something in there. I am also running my shocks on the axle.
07-08-2020, 12:54 PM | #3 |
I joined the Band! Join Date: May 2020 Location: US
| Re: Cheap/Easy SMT 10 stock lower link fix/ reinforcement |
07-08-2020, 01:15 PM | #4 | |
| Re: Cheap/Easy SMT 10 stock lower link fix/ reinforcement Quote:
The RTRs come with the spare ball in end with a screw threaded through there. The little extra piece of I-Beam fits above that. Does running the shocks on the axel put less stress on the link, or just change suspension geometry? Sent from my iPhone using Tapatalk | |
07-08-2020, 03:10 PM | #5 | |
Rock Stacker Join Date: Nov 2019 Location: uk
07-09-2020, 07:23 AM | #6 | |
Putting the shock on the axle changes the geometry and will stiffen up your suspension when using the same springs. Lots of the serious racers still use the shock on the link to get more travel out of a shorter shock. My decision was purely based on looks. No monster truck has the shocks mounted on the lower link (actually 1 does) | |
07-09-2020, 03:14 PM | #7 | |
I have to admit the front shocks look more scar to me moved out to the axle. I’m guessing if I run that I should put a little less preload on the shocks ? Sent from my iPhone using Tapatalk | |
07-10-2020, 07:04 AM | #8 |
| Re: Cheap/Easy SMT 10 stock lower link fix/ reinforcement Preload is easy to play with so just try it. Also the more straight up and down the shock is the stiffer the spring acts. if it is angled it starts to reduce the spring rate. Depending on the stance and size of jumps your doing you may want to play around with different oil thickness also. Suspension is a huge can of worms once you dive into it but its fun to try new things and see how it changes things.
07-15-2020, 04:57 PM | #9 |
Quarry Creeper Join Date: Jun 2018 Location: Hampton
I use Impact Resistant Resins on the daily. When I had mine I taped off the holes, mixed up the resin and poured it in the unused spaces. It worked perfect. Sent from my SM-G965U using Tapatalk |
07-19-2020, 08:40 PM | #10 | |
So you have a specific brand or trade name of that resin ? Or just off the shelf epoxy ? I’m curious now how Sent from my iPhone using Tapatalk | |
08-11-2020, 07:04 PM | #11 |
Wonder if filling that location with jb weld after some scuffing would help?
08-12-2020, 03:03 PM | #12 |
Cheap/Easy SMT 10 stock lower link fix/ reinforcement - Similar Threads | ||||
Cheap and easy rear link mount | Abrown83 | Axial XR10 | 13 | 12-01-2013 08:43 AM |
Broken RTR link? Here's a cheap and easy fix. | T I N Y | Axial Wraith | 9 | 10-11-2012 02:51 PM |
Axial: Broken Lower Link Mount Fix | cliff | Axial AX-10 Scorpion | 4 | 05-20-2011 10:58 AM |
Found a very cheap easy 4 link setup but need a little help! | tolofrhr | HPI Wheely King | 2 | 08-27-2009 07:18 PM |
Cheap/ easy upper link mounts | tjscrogins99 | HPI Wheely King | 3 | 05-31-2007 09:15 AM |
