08-13-2021, 06:32 AM | #1 |
Pebble Pounder Join Date: Jun 2006 Location: Saint John, NB Canada
| 6x6 Bullhead Clodbuster Build
I've been wanting to build an old school styled 6x6 Clodbuster for a long time now. I ordered up a Bullhead kit and robbed an axle off my Clod to get me started. This rig will eventually have a snow plow mounted to it so I wanted a heavy chassis so I'll be building it from 16 gauge steel. To start the layout for the chassis I measured the stock one with a caliper at various points for all the key suspension mounting points. New Bullhead kit I built the Bullhead and laid out the rear tires to get an idea for the wheelbase I wanted. Using my mad MS Paint skills for a rough rendering I took my measurements and laid them out on 1/8 fibre board and made a mock up chassis. I used a jigsaw to cut it out and and some wood for the cross members. I just wanted to be sure of fitment before building the metal chassis. Once I was happy with the setup I transferred it over to 16 gauge steel that I cut out with a grinder with a thin cut off disc and finished with some hand file work Pieces all tacked together using a mig welder In the above pics you can see the mill scale is still on metal, I did grind it away at the seems for the tack welds. I wanted to remove all the mill scale so I submerged the chassis in vinegar for a few a hours and this dissolves the mill scale and you can simply brush it off with your finger or bristle brush which is amazing considering how tuff the stuff is to remove short of using a grinder which marks up the surface. You can see the light grey area with the mill scale removed showing the bare steel I also made a stand from 2x4, helps for working on the truck and will also be for display to keep the tires from flat spotting on the shelf. More to come... |
08-13-2021, 06:33 AM | #2 |
| Re: 6x6 Bullhead Clodbuster Build
Some body work to the rear of the Bullhead Filler pieces I also have reinforced the body under these panels to prevent flex but forget to get a pic I'll be relocating the exhaust stacks and filling the original mounting holes Holes all filled and sanded smooth using styrene Sunroof deleted and filled with a piece of styrene and sanded smooth. I'll be adding roof lights and air horns. I moved the exhaust up and rearward using mounts I made from angle aluminum, these will be polished later on. Made my own sun visor from aluminum. Fairly easy to build, cut from aluminum sheet and make bends using a vise. This will be polished also later on. More to come... |
08-13-2021, 06:33 AM | #3 |
I polished the new exhaust mounts and made a roof spoiler to tie it all together for a finished look Also added some mirrors I ordered from rcmart.com I polished the sun visor Im pretty happy with how these parts turned out I'm doing away with the chrome wheels using Easy Off oven cleaner to melt away the chrome. Yellowish plastic in the Bullhead wheels And black plastic from the black edition Clodbuster Wheels primed and painted white using Tamiya spray paint Converting to a split window and adding wipers from a Grand Hauler kit More to come... |
08-13-2021, 06:34 AM | #4 |
Onto the paint work and masking, oh how I hate masking... Although I dont enjoy the process it is very satisfying removing the masking tape and seeing the end result. Tamiya masking tape works great. The colors and paint scheme are those from a local heavy hauling and crane company, I'll be adding their logo and some other detail stickers later on. |
08-13-2021, 04:59 PM | #5 |
Paint turned out great, and I really like the way it looks now with the stacks moved to the rear of the cab |
08-13-2021, 07:57 PM | #6 |
Yeah the paint and color scheme is pretty awesome, nice work!
08-17-2021, 07:48 PM | #7 |
Thanks for the compliments I printed some decals that I think turned out pretty good for just using a cheap printer. I used Avery 22822 clear labels which worked good for the KW logos where the background shows through the clear, but if you want white lettering or background like on my Irving Equipment decal then I had to print the same logo on white stick on labels and then the clear over top it. I made some aluminum plates for under the door and step, polished finish. Started building the snow plow mount |
08-18-2021, 04:56 PM | #8 |
Some more progress on the snow plow mount |
08-18-2021, 05:29 PM | #9 |
Rock Crawler Join Date: Apr 2014 Location: Portland
Paint turned out Awesome. Custom chassis looks Great. Can't wait to see that snow plow in action. |
08-19-2021, 08:11 PM | #10 |
Thanks Some more work on the plow today. I have the servo and fake hydraulic cylinder setup and the plow mount bolted to the truck. I'll be revising the linkage a bit to help get rid of some of the flex. Last edited by markturbo; 08-19-2021 at 09:13 PM. |
12-30-2021, 09:38 PM | #11 |
Got the plow finished up Last edited by markturbo; 12-30-2021 at 09:42 PM. |
12-31-2021, 11:49 AM | #12 |
So good! Dunno what to say, other than great build!
12-31-2021, 02:40 PM | #13 |
Pebble Pounder Join Date: Sep 2021 Location: Canada
What about a dump bed on the back with a salt/sand spreader?
05-04-2022, 07:24 AM | #14 |
RCC Addict Join Date: Nov 2008 Location: Bunnell, Fl.
That's one heck of a build, well done! |
05-23-2022, 09:47 PM | #15 |
Rock Crawler Join Date: Apr 2015 Location: San Marcos
That thing is really cool! Especially combined with it being a functioning plow. Great work!
6x6 Bullhead Clodbuster Build - Similar Threads | ||||
Bullhead Body Military 6x6 Build | TrailSnail | Multi Axle Rigs | 24 | 08-31-2020 12:01 AM |
Great, another Bullhead 6x6 build. | tcanin00 | Multi Axle Rigs | 56 | 11-01-2019 03:14 AM |
WesleyRoy's 6x6 bullhead to 8x8 flatbed truck build | WesleyRoy | Multi Axle Rigs | 13 | 05-14-2018 01:43 PM |
WesleyRoy's SCX10 another 6x6 bullhead build | WesleyRoy | Multi Axle Rigs | 47 | 03-16-2018 01:41 PM |
