Go Back   RCCrawler Forums > Scale Rigs General Tech > Micro Scale Rigs
Thread: Micro EB
Old 03-17-2010, 04:07 PM   #1
Default Micro EB
So i started out with a standard BND and added a bronco body i found at target (not exactly scale)
Well a couple weeks ago i found a better one in the for sale section, so now i will be stretching to get the right wheel base
Bought some aluminum wheels from RPP
And i have a set of so real boggers on the way, what do you think?
AkFordfan is offline   Reply With Quote
Old 03-17-2010, 05:22 PM   #2
Nice, the new wheels make it look awesome.
Raguvian is offline   Reply With Quote
Old 03-17-2010, 06:14 PM   #3
Looks good.
Gvus is offline   Reply With Quote
Old 03-17-2010, 07:51 PM   #4
did you get the urethane swampers?
Once you stretch them over the wheels they end up the same diameter as the stock tire.
The only problem is they are a bit narrow for the wheel, so the back side of the wheel sticks out a bit past the tire which sucks
also i hope yours are cast better than mine. I have smooth smears and air bubble holes in my tires.
I will say they are pretty grippy but being a solid tire these wont perform as well as stock losi on rocks
spoo76 is offline   Reply With Quote
Old 03-17-2010, 08:01 PM   #5
Looks great, I'll definitely be saving for a set of those..and nice driver What are your plans for a chassis for it?
Stampedekid is offline   Reply With Quote
Old 03-18-2010, 10:38 AM   #6
Thanks, not sure on the chassis yet probably just use the stock one for now and chop the upper shock mounts off. Depending on how much of the wheel is showing i might just cut the inside of the tire so it stretches and glue it to the wheel.thanks for the info
Old 03-27-2010, 02:21 PM   #7
Well i streched the wheel base with the steering links off my mini lst, and extended my rear driveline with an aluminum spacer
Old 09-14-2010, 12:40 PM   #8
I finally finished this thing the other day, not really any build pics i was on a roll
Eventually i want to build the cage out of metal but it will make it real top heavy
Old 09-14-2010, 02:47 PM   #9
/\ maybe brass in styrene tubing would do the trick? (for your cage.)
I like that ford body, is that a playmobil toy ?
murdock is offline   Reply With Quote
Old 09-14-2010, 03:18 PM   #10
The driver is, the body is off one of those cheap toys that just goes in a straight line.
Old 09-14-2010, 06:22 PM   #11
nice work man! I really like that body.
MGCrawler is offline   Reply With Quote
Old 09-14-2010, 06:46 PM   #12
ei9
so cute
ei9 is offline   Reply With Quote
Old 09-15-2010, 09:09 PM   #13
Got some new upgrades today, Hot racing turnbuckles for a rc10 i think and used them for the rear links, and the hot racing straight axle. Looks pretty sweet, may have to get another turnbuckle kit to do the front links
