Go Back   RCCrawler Forums > Scale Rigs General Tech > Micro Scale Rigs
Thread: Raptor build
Old 02-10-2013, 11:17 PM   #1
Default Raptor build
Just picked this up... Steel body with plastic details.. It's a 1/24 scale and I will be using the running gear from a losi micro. I plan to build an abs tonneau cover to conceal the battery and electronics in the bed. Also ordered a 1/24 trailer so I can use this to haul a micro sct.
Sent from my Droid DNA using Tapatalk 2
TnMan is offline   Reply With Quote
Old 02-11-2013, 02:48 AM   #2
Managed to recess the motor and trans up into the passenger compartment and only had to raise the back seat by 3/16 of an inch. Only the mounting bracket is glued, the trans still screws in place and can be easily removed with 3 screws.
Sent from my HTC6435LVW using Tapatalk 2
Old 02-11-2013, 02:52 AM   #3
I plan to swap out the wheels and tires for some a little smaller but here are some mockup shots with the stock losi ones...
The receiver/esc fits perfectly under the mock engine
Old 02-11-2013, 02:56 AM   #4
Default Re: Raptor build
That's sick! What are you thinking of getting for smaller tires/wheels?
téosrc is offline   Reply With Quote
Old 02-11-2013, 02:56 AM   #5
I plan to build a combination trans skid plate / link mount and some trim panels to fill in the middle sections. Any one know if the rc4wd nano t-rex axles are ever going to be available?
Old 02-11-2013, 04:04 AM   #6
I'm still looking for the right ones... I seem to remember seeing some micky Thompson baja tires that were pretty small but have to try and find them. But I would like something like that that would be scale accurate
Old 02-11-2013, 04:36 AM   #7
This is sick!! Definitely interested to see how this comes out since I love the raptor and have a micro laying around.
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
BADASSPONY is offline   Reply With Quote
Old 02-11-2013, 06:51 PM   #8
baja claws would look good. Great project so far
Corey303 is offline   Reply With Quote
Old 02-13-2013, 07:43 PM   #9
Should have some progress soon.. Waiting on an order of 1.8mm leds and some micro rally tires. Also picked up a 1250mah 2s lipo
Old 02-16-2013, 08:46 PM   #10
wheels and tires from an xmod truck would get you close to a stock look, a little small for my liking, but it could work
rockycrawlslowa is offline   Reply With Quote
Old 02-19-2013, 11:43 AM   #11
I'm hoping that the micro rally tires on the micro crawler axle will be what I'm looking for.. But if not those will be the next ones I try. Finally got in some 1.8mm leds, but still waiting on the silicone wire and resistors, and still trying to decide between the 4 link setup or some leaf springs like the 1:1 in the rear.
Old 02-19-2013, 09:25 PM   #12
You should go with leaf springs because of the weight of the die-cast and because you will be using it for towing. The stock wheels and tires look cool, anyway to make them work?
rcdave13 is offline   Reply With Quote
Old 02-21-2013, 11:56 AM   #13
I decided to go with leafs, both for the weight and looks, now I just have to make them lol
Old 02-21-2013, 06:43 PM   #14
Sick build! What plans for a motor do yu have?
For tires look for some aoshima super swampers those would fit perfect! Inbetween xmod tires and losi tires.
jprock is offline   Reply With Quote
Old 02-21-2013, 08:10 PM   #15
The motor is already mounted under the rear seat.. It's from a losi micro crawler
Old 02-22-2013, 05:53 PM   #16
Got the trailer in today.. Probably will have to upgrade the wheels and axles but I like it..
Old 06-19-2014, 05:23 AM   #17
I joined the Band!
any progress on this old thread????
RootBreaker is offline   Reply With Quote
Raptor build - Similar Threads
Ford "Rock" Raptor build (1/6 Newbright) fbuonpensiero 2.2 Scale Rigs 39 12-19-2012 09:11 AM
svt raptor scale build King James Paint and Body 14 11-27-2011 09:36 AM
Raptor Build savagedrifter112 Losi Micro-Rock Crawler 3 01-28-2010 09:20 PM
My Super Raptor build SHEMP$TOOGE$ General Crawlers 4 12-10-2009 12:32 AM
