04-17-2014, 12:39 PM | #1 |
Rock Crawler Join Date: May 2009 Location: Hillsboro, OR / Kapolei, Hi
| Wheel mod to make a wider wheel.
I do the same mod to SCX10 wheels. Cut one wheel in half. The rear half is a perfect barrel donor. Dremel out the front half and you have another barrel. Glue barrel to front side of a stock wheel. Voila! |
04-17-2014, 01:03 PM | #2 |
Quarry Creeper Join Date: Jan 2013 Location: LP, LA
| Re: Wheel mod to make a wider wheel.
Got pics of the parts before final assembly?
04-17-2014, 02:12 PM | #3 |
| Re: Wheel mod to make a wider wheel. |
04-17-2014, 02:14 PM | #4 |
Cut the center hub out and there u have two barrels.
04-17-2014, 11:43 PM | #5 |
You did a very nice job with that. I have seen a couple of similar widening mods before. They each used a single wheel to do the mod.
05-22-2014, 10:24 AM | #6 |
Pebble Pounder Join Date: Feb 2012 Location: Buffalo
This looks awesome. Are you using two wheels to make one wheel?
Wheel mod to make a wider wheel. - Similar Threads | ||||
Wider Wheel Hex? | SCX10Dingo | Axial SCX-10 | 8 | 04-04-2013 12:38 PM |
sedonas on AX-10 need more off set and wider wheel. | bustedbinder | Tires and Wheels | 12 | 02-08-2013 10:24 AM |
Will a DNA206 berg wheel make a wraith more narrow or wider??? | BRANDON1987 | Axial Wraith | 4 | 12-14-2011 08:27 PM |
Wider wheel hexes out there than these? | jeepster73 | Losi Mini-Rock Crawler | 6 | 01-27-2011 09:44 AM |
Wider wheel hex ? | LIFTED-ZJ | Axial SCX-10 | 9 | 06-30-2010 10:10 PM |
