10-08-2017, 02:45 PM | #521 |
Newbie Join Date: Feb 2017 Location: Chicago
| Re: RC4WDs New Micro Crawler
Not sure if this is helpful, but you could probably make a transmission out of an old servo. I have an old savox with a fried board, but the motor and gears were good so i took out the board unsoldered the motor and soldered on some jst connectors to work with an esc. Then i tapped all the way through the metal output gear with a m4 tap and used some m4 threaded rod as the output shafts (the shaft that attaches to the axle). It is pretty slow but has massive torque! (207 oz in) If you want more speed you can glue the spur gear (the first gear that the motor drives) to the 2nd to last gear (the one that makes contact with the output gear) and this lowers the torque but gives you about 5x the speed from my experiences. I run the glued gear servo trans on a rig i built that uses trekker axles. It is probably about half the speed of a stock trekker on 2s. Hope this can maybe help someone
10-09-2017, 10:17 AM | #522 |
Newbie Join Date: Sep 2016 Location: Seattle
Following the instructions here, I did the servo motor upgrade and then threw in an old hobbywing esc... Couldn't help but try a 3S. Long story short - a wheel came loose and I lost one of the drive pins. Anyone know where I could source some spares? As an aside - the servo motor handled 3S like a champ. Barely got warm during the 3 minutes of drifting around the living room. Thanks! |
10-17-2017, 02:10 PM | #523 |
Newbie Join Date: Dec 2016 Location: Mustang, OK
For the drive pin, I lost one when redoing the suspension, and I had a paper clip that was basically the exact same diameter. I just cut a short piece off, slid it through the hub, and it worked perfectly. Still going strong! Glad to hear the servo motor handles 3S! Mine should be arriving this week, so I’m eager to see how it does. I’ve tried 4 different motor setups now and haven’t been happy with any of them, but this one sounds like it should do the trick. |
10-17-2017, 06:21 PM | #524 | |
Rock Crawler Join Date: Jan 2012 Location: Champlin, MN
| Re: RC4WDs New Micro Crawler Quote:
10-17-2017, 08:26 PM | #525 | |
I did the same thing with the driveshaft on one of my motor/trans setups, though! Haha I had an extra set of driveshafts, so I wasn’t too worried about it. In fact, there’s still a piece of a screw holding my Ambush’s driveshaft on, since U-joints/driveshafts have never become available for them. Works like a charm! | |
10-19-2017, 08:54 PM | #526 |
Alright, the verdict is in: the servo motor reigns king! Good gosh, what a huge improvement. The dual motor setup was GARBAGE. I stripped out the gearboxes on 4 motors within about 15 minutes of wheeling. The Sumo motor and trans was plenty torquey and had great control, but the factory plastic gears were junk (again, stripped them very quickly), and it was VERY slow. I went to the Devastator metal gear upgrade and long can motor on 3S, and it was better (still very slow, but less so), and the metal gear upgrade STILL leaves the plastic output gear (come on, there’s only TWO GEARS in there. I wasn’t asking for much... Haha). But as you might imagine, the last remaining plastic gear stripped, and there is no readily available metal replacement. At this point, I just let it sit until I could come up with something better later on. ENTER THE MG958. All along, I wanted to do something that could use the original transfer case, if possible, so when I saw this servo motor mentioned, I was quite interested. Ordered it up, soldered my beefier wires and connectors on, filed the hole in the trans open to fit the motor (quick and easy), dabbed a little fresh grease in there, ground down the upper rear link bolt to clear the motor, and VOILA! Looks like it could be a factory part. The low speed control is significantly better than the stock motor, the torque is fantastic (and it easily picks up the front tires from a stop on 3S, if you feel so inclined), and not only does it have all of the fun ‘thrashing’ speed of the stock motor, but it actually has more of it! Literally nothing but pros with this upgrade, no cons. It makes it an awesome little all-arounder, but if you don’t want all of the speed (which I’m quite enjoying), finding a pinion with a couple less teeth would make the torque ridiculous. If you’re on the fence...DO IT. You won’t be disappointed. Last edited by guards951; 10-19-2017 at 09:32 PM. |
10-23-2017, 12:59 PM | #527 |
Yup, the pin that fits into the wheel hex. RC4WD will sell 4 for $12 including shipping. Trying to find out how much of that is shipping / if it's worth it if I'm already ordering something else. Otherwise, sounds like I'll have to find an appropriately sized screw. Regarding suspension, I used: HOT-RACING MCC543T06 Blue Internal Spring Air Shocks 43mm. Swapped out the lower end for the RC4WD ones. The uppers I sandwiched with the included o-rings. Provides more travel than the stock (straightened) links do and IMO look great. |
11-04-2017, 12:51 PM | #528 | |
Rock Stacker Join Date: Oct 2009 Location: Phoenix
Love this little guy, so much potential!!! It's not gonna be as wild a other 1/18 crawlers out there but this is more scale than performance. I ordered the motor from banggood for $10.00!! Last edited by Twisted Links; 11-04-2017 at 02:35 PM. | |
11-21-2017, 01:30 PM | #529 |
Pebble Pounder Join Date: Oct 2015 Location: Fraggle Rock, CO
FINALLY got off my butt, shot a video and actually used my comp to play with it, adding music, stupid intro and whatever. think it came out decent but, damn, i wish i had the camera turned 90 degrees...... hope yall enjoy. https://youtu.be/u_hepnmVOok |
11-22-2017, 11:26 AM | #530 |
[QUOTE=SurfinStud;5769045]FINALLY got off my butt, shot a video Looks like it has good power. its kinda jerky. Is that your driving or the way the power comes on. In the process of building mine and I order the servo motor, hoping its smooth so it looks scale when moving. |
11-22-2017, 11:38 AM | #531 | |
[QUOTE=Twisted Links;5769320] Quote:
I think more drive time on rocks will get me more familiar with it, resulting is better throttle(finger) control. Also, it drives way different than my scx10, soooooo, going from one to the other is a bit to refamiliarize with. Gearing is a bit tall, so its ability to creep is limited too. Sent from my VS987 using Tapatalk | |
11-22-2017, 05:33 PM | #532 | |
[QUOTE=SurfinStud;5769326] Quote:
All in all I'm super happy with it now. I moved the lower links to the outside of the chassis rails, removed the white bushing from inside the shocks and loaded it with grease, loaded the diffs and transfer case with grease and with just a $10 motor and nothing else I think she's perfect. | |
11-23-2017, 04:16 PM | #533 |
Newbie Join Date: May 2017 Location: Malgrat de Mar
This is mine. |
11-23-2017, 06:23 PM | #534 |
Can anyone suggest an esc? She pulls out to fast! Need more control in tight spots. https://youtu.be/pI8nmXpC3ng Last edited by Twisted Links; 11-27-2017 at 04:40 PM. |
11-28-2017, 02:12 PM | #535 | |
11-28-2017, 02:19 PM | #536 | |
I wanna be Dave Join Date: Feb 2007 Location: South FL
They are available shipped for around $35-45 and have 3 channels. The receivers are inexpensive and easily found. Another plus is the radio is easily hackable to get you 6 or 8 channels, button mapping to make any of the buttons work with nearly any channel and you can make the buttons work as momentary short press,long press, 2 position, 3 position, or multi position step rate in any order Sent from my SM-N900T using Tapatalk | |
11-28-2017, 05:22 PM | #537 | |
You know its really a shame,,,I didn't wanna get into the electronics of this model. I thought I paid to much already, and I'm really happy with everything after the servo motor was installed,,,,it's just that take off speed is not slow enough. | |
11-28-2017, 05:45 PM | #538 |
I love my hacked gt3b's, but I also have a Spektrum DX3R I use with my Losi Micro ESCs. Btw If you have the Axial AX-3 transmitter with the AR-3 receiver then that same receiver is used for the GT3b and GT3c, that should allow you to use cheap replacement/spare receivers and make for an easy transition to a GT3B or C if you'd like all those extra features of a hacked radio. Axial AX-3 Review and tear down |
11-28-2017, 07:56 PM | #539 | |
11-29-2017, 02:18 PM | #540 | |
Pebble Pounder Join Date: Feb 2015 Location: Cambridge, UK
Sent from my Nexus 6P using Tapatalk | |
RC4WDs New Micro Crawler - Similar Threads | ||||
BWD Micro Wheel Weight System for the new Losi Micro Crawler! | billet works | Vendors Market | 19 | 10-18-2010 05:42 PM |
~Petition for RC4WDs next 1.9, 3.7" tall tire~ | STANG KILLA SS | Tires and Wheels | 105 | 02-03-2008 02:17 AM |
RC4WDs Aluminum 2.2 Hilux wheels | SuperSancho | Tires and Wheels | 5 | 04-29-2006 12:42 PM |
