Go Back   RCCrawler Forums > Scale Rigs General Tech > Micro Scale Rigs
Thread: RC4WDs New Micro Crawler
Old 09-30-2018, 02:56 PM   #561
Default Re: RC4WDs New Micro Crawler
after 1 hour of playing in doors.. the motor went bye bye..
I mean common! I emailed RC4WD and told them to send me a replacement
Raman is offline   Reply With Quote
Old 10-02-2018, 06:05 AM   #562
Is this with the old, metal cased transmission?
Or the new v2, plastic case, transmission?
Old tranny motor combo burnt up real quickly.
Sent from my VS987 using Tapatalk
SurfinStud is offline   Reply With Quote
Old 10-02-2018, 09:36 AM   #563
Its the new one. Itís a brand new kit from Tower.. D90 with blue body.
I email RC4WD already.. I also read up on this thread and installed a servo motor.. I had a JR Landing gear servo that never liked to talk to my futaba.. so I opened it up and pulled that motor. Itís working fine does run how but hasnít burned.
So it appears the only brushless option would be a brushless motor from a brushless servo! An expensive proposition!
Old 12-15-2018, 03:18 PM   #564
Iíve installed the Crawlster kit. In my opinion the turning radius itís quite better. A bigger toe out gives you better mobility in small spaces. And the suspension kit provides you more flex, just a little. But enough for a better performance.
Andersen72 is offline   Reply With Quote
Old 02-24-2019, 06:12 PM   #565
Does anyone have any recommendations for center drive shafts? The RC4WD ones keep loosing pins. And Im not talking about the ones under the o rings.
BIGW0RM is offline   Reply With Quote
RC4WDs New Micro Crawler - Similar Threads
BWD Micro Wheel Weight System for the new Losi Micro Crawler! billet works Vendors Market 19 10-18-2010 05:42 PM
~Petition for RC4WDs next 1.9, 3.7" tall tire~ STANG KILLA SS Tires and Wheels 105 02-03-2008 02:17 AM
RC4WDs Aluminum 2.2 Hilux wheels SuperSancho Tires and Wheels 5 04-29-2006 12:42 PM
