Go Back   RCCrawler Forums > Scale Rigs General Tech > Micro Scale Rigs
Thread: RC4WDs New Micro Crawler
Old 03-14-2016, 08:42 PM   #101
Default Re: RC4WDs New Micro Crawler
Shock bushing removal. The shock also has a brass guide in the cartridge area, plus the 4-link doesn't allow side movement anyway, so I think it's OK to ditch them. The springs are still too stiff, but adding length (and removing most of the preload) helped a lot.
The bushing in question:
Clingman is offline   Reply With Quote
Old 03-14-2016, 08:48 PM   #102
Originally Posted by derycksan View Post
Got mine as well, cute, but a bit under performing. Motor/gearing has no grunt and flex is barely a quarter tire. Oh well, ill order a tamiya motor and mess with gearing. Was for putting around my desk anyways. I did like the amount of metal througout the chasis though.
Sent from my SM-G900P using Tapatalk
Here is a comparison shot.
Old 03-14-2016, 08:50 PM   #103
You removed the white part?
tacocat is offline   Reply With Quote
Old 03-14-2016, 08:58 PM   #104
Wow nice improvement there. Keep up the good work.
Sent from my iPhone using Tapascrap
tgh117 is offline   Reply With Quote
Old 03-14-2016, 09:13 PM   #105
Yes sir. It rides on a portion of the shaft that has a reduced diameter, so I was afraid that it might hang on the brass cartridge bushing. But, the brass bushing is nice and long, so the shaft can't hang up. The shocks run smooth. In fact, one of mine had a draggy white bushing so that one actually runs better
Old 03-14-2016, 09:41 PM   #106
Awesome thanks
Mine gets here in two days
I can't waitttttttttt
Old 03-15-2016, 12:50 AM   #107
i was planning on building a challenging little course for me and my son. hopefuly it dont cost to much to upgtade
Erik R is offline   Reply With Quote
Old 03-15-2016, 05:57 AM   #108
Now at least my rc4wd axle truck has a younger brother.
ManicMechanic is offline   Reply With Quote
Old 03-15-2016, 06:25 AM   #109
Great now I need one, but I wonder if a cruiser body is in the works or maybe a mini TF2.
mtnbiker4evr13 is offline   Reply With Quote
Old 03-15-2016, 09:58 AM   #110
Looking at the pics and descriptions from the early adopters here in the thread, I feel like RC$WD didn't really intend this to be a performer. I feel like this is more like the highly detailed (and expensive) Tamiya display models, just with the option of being functional. I see a lot of these looking pretty on desks and shelves, with the occasional jaunt over some office supplies.
I still want one though. How does the motor attach? Think it would be easy to rig a divorced setup?
Derek Larsen is offline   Reply With Quote
Old 03-15-2016, 10:13 AM   #111
It's interesting, because it has the potential to be a performer, right up to the point that they put dinky shocks and a too-small, too fast motor and gear ratio in it. It's *almost* there.
That being said, you guys are going to have to help me with motor options and where to find them because I'm new to this kind of r/c and I can't see the classifieds to see if there are applicable motors in there or not...
Old 03-15-2016, 10:58 AM   #112
Do you have any other micros to compare the motor to? Its hard to judge size in the picture,but it looks like a standard 130 can motor which was also used in xmods & miniZ back in the day. Danally also does custom wound DDT/Predator "big block" motors in that size
spoo76 is offline   Reply With Quote
Old 03-15-2016, 11:24 AM   #113
Glad the shocks can be sorted easily enough. It's still a bit arthritic looking but it's early days yet. Mine was in London at 2pm today, and I've got a day off tomorrow...
Sparks1337 is offline   Reply With Quote
Old 03-15-2016, 11:32 AM   #114
I have a few Danally "Stroker" motors which are the same size as his big blocks, just a longer can. They are torque kings! Major torque compared to other similar sized motors. And you can have him custom wind them for you. I have a 60t, 80t, and a 90t. For this particular rig though I was thinking of a 110t with castle sidewinder esc, and 3s power. Not having one in my hands to tinker with, I'm really not sure that would fix it, but it's where I would start. Plus I kinda like 3s power.
R.Billy Rob is offline   Reply With Quote
Old 03-15-2016, 11:33 AM   #115
I don't know the diameter of the outdrives but I was thinking of even goin so far at to try a Losi micro crawler trans. Got home yestersday and got to look at mine for about 5 minutes then had to watch my kids.
cutlaSS is offline   Reply With Quote
Old 03-15-2016, 11:59 AM   #116
I realize the size of the 180 strokers compared to the 130 big block. I sent him my 180s to experiment on before he made the strokers available. I still have the intial 4 prototypes he wound for me. A 100T, 2 97T, and a 57T for speed and some torque. I forgot the various gauge wires he used. The reason I asked if anyone had a 130 can big block was to compare it in a photo to the RC4WD motor. I have a few strokers,big block and stock Losi size wound motors but don't have the RC4WD yet. Hopefully I'll grab one!
Old 03-15-2016, 12:52 PM   #117
Would a gear reduced motor work?
http://m.banggood.com/Orlandoo-OH35P...-p-968516.html
Brake Weight is offline   Reply With Quote
Old 03-15-2016, 12:55 PM   #118
Oh, one other thing. The manual that came with this is a complete, fully illustrated, step by step assembly manual for the chassis. It really looks like it was made to be a kit at some point. I know that'll make some of you happy
Old 03-15-2016, 03:34 PM   #119
Good idea Brake Weight - I think that one you linked to will be too small though, even with the reduction. It'll need at least a stock losi size can with reduction box - plenty on fleabay if you look for 16GA gear motors (16mm OD can).
It'll probably actually only need 3:1 reduction or something unless you want a creeper.
If it is a big block then gear motors are harder to find - 20ga size and so far the only ones I've seen are sold by the 100 on alibaba
Old 03-15-2016, 04:53 PM   #120
tThe reduction Brake Weight posted looks like the RC4WD winch replacement reduction so I think the RC4WD unit has enough torque to pull some heavy rigs. The truck would probably be slow as hell but have good torque.
http://http://store.rc4wd.com/Replac...ch_p_3665.html
never mind, final drive is 52 rpm
RC4WDs New Micro Crawler - Similar Threads
BWD Micro Wheel Weight System for the new Losi Micro Crawler! billet works Vendors Market 19 10-18-2010 05:42 PM
~Petition for RC4WDs next 1.9, 3.7" tall tire~ STANG KILLA SS Tires and Wheels 105 02-03-2008 02:17 AM
RC4WDs Aluminum 2.2 Hilux wheels SuperSancho Tires and Wheels 5 04-29-2006 12:42 PM
