10-27-2016, 08:03 PM | #1 |
Quarry Creeper Join Date: Jun 2014 Location: Grand Haven, MI
| Orlandoo ESC won't play nice with Flysky
Hey guys. Got all my electronics in for my Orlandoo, but no kit yet. I decided to test out the electronics in the meantime. I have tried 3 different Flysky receivers, all exhibit the same issue. This does NOT happen with my expensive Futaba. That works perfect. Here is the issue: When I turn on the ESC, the motor starts moving by itself. If I squeeze the trigger about 1/3 of the way in, it stops. I can't get the motor to stop moving any other way than that. Throttle trim will slow it down, but not eliminate it. I have also tried: reversing throttle channel rebinding disabling ABS/Expo/etc and fiddling around for an hour. Anybody have anything like this happen? I can't be the only guy with this ESC and a flysky, as Sam posted the pics of this truck with a flysky rx lol. Please help!!!!! |
10-27-2016, 08:12 PM | #2 |
| Re: Orlandoo ESC won't play nice with Flysky
What ESC are you using?
10-27-2016, 08:16 PM | #3 |
The Orlandoo unit with LED control
10-27-2016, 08:34 PM | #4 |
Quarry Creeper Join Date: Sep 2009 Location: Las Vegas
I'm using a flysky with no such issue, have you tried a different esc?
10-27-2016, 09:03 PM | #5 |
FIXED IT!!!!!!!!!!!!! Apparently you can calibrate the GT3B. Had no idea. It explains why some "auto learn" ESCs were a bit wonky with that remote. Honestly this thing feels better than ever. I'm just going to periodically calibrate mine from now on. Here is how I did it. To enter menu turn radio on, turn wheel full right then press and hold enter. (eventually I let go of enter and it started) With the 1 displayed on your left Hold ST Wheel full left till numbers stop moving, Press enter Let ST Wheel center, once numbers stop changing press enter Turn wheel full right, once numbers stop changing press enter Now press END to move to channel 2 Hold trigger full throttle, let numbers stabilize press enter Let trigger center, let numbers stabilize press enter push trigger full reverse, let numbers stabilize Press enter Then I pressed either "back" or "end" (sorry i can't remember) and it brought me back to the main screen. |
10-28-2016, 05:45 PM | #6 |
Rock Stacker Join Date: Nov 2011 Location: Jackson, California
A lot of times its the epa or end point adjustment that needs to addressed.
11-05-2016, 07:42 AM | #7 | |
Quarry Creeper Join Date: Oct 2016 Location: West Michigan
| Re: Orlandoo ESC won't play nice with Flysky Quote:
you're in GR? Im in Allegan. | |
Orlandoo ESC won't play nice with Flysky - Similar Threads | ||||
Orlandoo ESC alternatives | 1967Typhoon | Micro Scale Rigs | 4 | 10-10-2016 10:01 AM |
modded flysky and 4ws/dual esc help | Newfie | Electronics | 8 | 06-12-2013 06:25 AM |
Flysky gt3b with stock ESC | acesal | Redcat Crawlers | 21 | 11-29-2011 10:27 PM |
