01-12-2017, 07:58 PM | #41 |
Quarry Creeper Join Date: Oct 2016 Location: West Michigan
| Re: Orlandoo wiring
I do not know, but on yours, did the front axle move side to side? Mine doesn't steer very well and the whole axle shifts
01-12-2017, 08:22 PM | #42 |
Rock Crawler Join Date: Aug 2011 Location: south shore Ma
| Re: Orlandoo wiring
I did have that problem. Im pretty sure its because of the chassis mounted servo and 4 link. Its needs a panhard bar and 3 link. I ended up putting a longer servo horn and it fixed most of it. I just finished installing the 300 rpm motor. Way better! Also somehow my servo came back to life. I got to drive it around for a few packs tonight. Im pretty impressed with it now. Sent from my ALCATEL ONE TOUCH Fierce using Tapatalk |
01-13-2017, 12:13 PM | #43 | |
| Re: Orlandoo wiring Quote:
01-13-2017, 12:28 PM | #44 |
| Re: Orlandoo wiring
I might mess with my lights tonight too. I havent even done anything with them at all. Im not sure how the small leds work yet. I can at least get the headlights working. Sent from my ALCATEL ONE TOUCH Fierce using Tapatalk |
01-13-2017, 01:22 PM | #45 |
| Re: Orlandoo wiring I had mine working well, but with all the ****ing around w/ all the shit, the wires just keep breaking off. they are so fragile
01-13-2017, 04:24 PM | #46 |
| Re: Orlandoo wiring
My axle is moving because the motor mount that has the 8 rod balls attached to it has one of the ears broken. I broke it during assembly but didn't think it would be a problem. It's a problem. It's the upper link mount, chassis side on the left. You can see how it's not tight to the plastic. Dammit |
01-14-2017, 09:02 AM | #47 |
Newbie Join Date: Jan 2013 Location: Usa
| Re: Orlandoo wiring
Hi I ordered the 2.2g servo from Amain for the Orlandoo and its to big for the f150. Is the ford and jeep servos different? It doesn't even fit in the bracket and also the plug on the servo is different than a regular servo. Do I have to have a special receiver to plug use or cut that plug off and install a normal sized servo? Or try unsoldering the prongs on a regular receiver and solder the wires directly to it?
01-14-2017, 09:14 AM | #48 | |
01-14-2017, 09:37 AM | #49 |
| Re: Orlandoo wiring
On the jeep the servo has a small low voltage plug that plugs into the esc. Im pretty sure if you change the plug to a standard one and plug it into a rx it will over power the servo. What does the f150 have for electronics? I assumed they were the same. Sent from my ALCATEL ONE TOUCH Fierce using Tapatalk |
01-14-2017, 09:44 AM | #50 |
Rock Stacker Join Date: Sep 2010 Location: uk
| Orlandoo wiring
Pretty sure they are the same electrics, the 2.2g servo will only fit the f150 if you use the metal axle upgrades as they have adjustable brackets for the servo if I recall correctly. Sent from my iPhone using Tapatalk |
01-14-2017, 10:14 AM | #51 |
Newbie Join Date: Jan 2017 Location: Langevåg
| Re: Orlandoo wiring
F150 uses the slightly smaller 1.7G servo. The special plug is because the orlandoo servos are low voltage, and they fit the orlandoo esc/light/servo controller combo Sent fra min SM-G800F via Tapatalk |
01-14-2017, 11:43 AM | #52 |
| Re: Orlandoo wiring
Ok. So does someone have a link to the esc for the f150? Preferably a seller in the us? If not atleast a link so I can see what I need? And for the plugs, so I need a special receiver? I ordered a flysky fsi6 and fsia6 will that receiver work? I can try to post pics of what I have if needed
01-14-2017, 12:01 PM | #53 |
| Re: Orlandoo wiring
The flysky rx should work fine. The esc has a wire that plugs into the channel one plug but it only has one signal wire. Then the servo plugs into a port on the esc Sent from my ALCATEL ONE TOUCH Fierce using Tapatalk |
01-14-2017, 12:22 PM | #54 |
| Re: Orlandoo wiring
You can use a normal receiver. The Orlandoo electronics have a normal esc-receiver plug and also normal plugs for steering and lights channel. The servo plugs into the Orlandoo electronics Sent fra min SM-G800F via Tapatalk |
01-14-2017, 12:44 PM | #55 |
| Re: Orlandoo wiring
Thanks so much for the help. Any suggestions on where to get the servo? I should look for a 1.7g servo INSTEAD of the 2.2 correct. I'd Would like a us seller for quick shipping if anyone has any suggestions
01-14-2017, 12:50 PM | #56 |
| Re: Orlandoo wiring
For the f150 you need the 1.7 yes. I dont know if their quick but I think banggood.com has both the electronics and servo Sent fra min SM-G800F via Tapatalk |
01-14-2017, 12:54 PM | #57 |
| Re: Orlandoo wiring http://www.rcmart.com/oh35p01-parts-...cPath=595_1801 http://www.rcmart.com/oh35p01-voltag...cPath=595_1801 Here is the links for Esc and servo from rcmart. I have No personal expeeience Sent fra min SM-G800F via Tapatalk |
01-15-2017, 07:57 AM | #58 | |
Sort by USA shipping. Could also try this one 1.7G Low Voltage Digital Servo Orlandoo OH35P01 KIT RC Car Part Electric Part | eBay Last edited by nate94gt; 01-15-2017 at 08:00 AM. | |
01-15-2017, 02:21 PM | #59 |
| Re: Orlandoo wiring
Will the 2.2 servo plug into the esc tho? I mounted the servo in the square spot about the axle with servo tape and it seems to Be holding very good I haven't received the esc yet tho so no way to tell
01-15-2017, 02:39 PM | #60 |
| Re: Orlandoo wiring
I was wondering the same thing. Mine is working for the moment but the extra power would be helpful when my new tires show up Sent from my ALCATEL ONE TOUCH Fierce using Tapatalk |
Orlandoo wiring - Similar Threads | ||||
Orlandoo Jeep | AZDIGGER | Micro Scale Rigs | 12 | 10-31-2016 02:44 PM |
Orlandoo - A Little More Speed? | Shucky | Micro Scale Rigs | 1 | 10-05-2016 12:45 PM |
New Orlandoo | Joostproost | Micro Scale Rigs | 1 | 09-07-2016 10:48 AM |
Another 1/35 Orlandoo...nooooooooo | Brake Weight | Micro Scale Rigs | 9 | 07-28-2016 02:43 PM |
