Go Back   RCCrawler Forums > Scale Rigs General Tech > Micro Scale Rigs
Thread: Ambush LN107 twin cab
Old 01-11-2017, 02:57 PM   #1
Default Ambush LN107 twin cab
G'day all, to start with this probably isn't going to be very well documented but if I take a pic it'll end up here.
thought it was about time the ambush got something to set it apart from everyone else's, so after a bit of math from real measurements and a bit of hope they made it exact to scale I ordered this, Aoshima 1/24 LN107 hilux double cab.
I picked this variation of the kit mainly because of the many option parts included like spot lights, sliders, rear bar, roll bars and fender flares.
Seems it should fit pretty alright at this stage,
Bonus is, my math was pretty spot on and the wheelbase and length should work pretty perfect. Width at this stage is slightly too thin but once the flares go on it should be better.
My plan (at this stage) is to try and use stock ambush elecs and hopefully make them fit with (or most of) an interior. Not sure if I'll use the tub or make a tray up for it yet but time will tell.
Anyway, that's it for now.
Happy scales!
joely is offline   Reply With Quote
Old 01-12-2017, 04:02 AM   #2
Default Re: Ambush LN107 twin cab
So far I've stared at for a long while, cut a few holes to get the floor pan to sit on the frame, chopped up the tub a little for the rear shock mounts and got the esc/rx mounted under the tub between chassis rails. Also pretty sure I've worked out how to sort of hide the battery, it may take away a bit of interior but from measurements it shouldn't be too much.
And sat the body on to see how it sits, not too shabby! The tub sits a few mm lower then that on properly
Old 01-12-2017, 12:39 PM   #3
Natedog's Avatar
Love the double cab Toyotas, wb and all looks to be great fit, some fender flares will complete it as you said. Take your time cutting the floorboards (as you are) and keep us updated!
Old 01-12-2017, 01:42 PM   #4
Definitely took my time to cut up the floor boards, those small holes are the result of 2 hours measuring and rechecking just wish I did the same with the tub, already have to fill a bit of wheel well back in.
I cannot for the life of me work out where to hide this huge pain in the ass stock battery so I'm thinking lipo replacement.
Which leads me to the question, can the li-ion be directly replaced with lipo without having to replace the ESC/RX system?
Old 01-15-2017, 03:58 PM   #5
We had a pretty cool weekend (31°c instead of 43) so not much got done cause I was fishing
But I did start this
Edit: the cage has exploded twice on me so I'm done with it for now, might try again later in the build
Old 01-17-2017, 01:46 PM   #6
I'll just leave this here getting to my favourite part... Paint.
Old 01-18-2017, 02:15 AM   #7
Gah - my least favorite part that usually craps up all the blood, sweat and tears...
(Maybe I should clean them off first)
jimbo_wa is offline   Reply With Quote
Old 01-18-2017, 05:04 PM   #8
i find washing them before makes a lot of difference. I wash mine between every different coat after a light sand. It probably won't come up like I'm hoping but I've given it the best odds I can.
Old 01-19-2017, 03:33 AM   #9
Got a little more done today, hand painted the interior. Not bad for a first go at brushes in ages. 3 hours later
I also sprayed the body color but its staying hidden till some detail goes on.
Old 01-22-2017, 09:36 PM   #10
Its way too hot to be outside today so i finished up the interior. Pretty happy with it.
Old 01-23-2017, 11:12 AM   #11
Interior turn out great, keep up the good work. I can't wait to see it finished.
HilltopRcCrawlers
doug.steele04 is offline   Reply With Quote
Old 01-24-2017, 01:25 PM   #12
Decided last night it was about time for abit of a mock up. Its still missing a few bits here n there and still needs clear coat but close enough to give an idea.
Annnd inside
Width also worked out pretty well after flares
Just can't decide on a number plate yet and still waiting on a bunch of LEDs so I can do all the lights an wiring
Old 01-24-2017, 03:11 PM   #13
Nice looking truck.Did the fender flares come with the body?
seedburns is offline   Reply With Quote
Old 01-24-2017, 03:13 PM   #14
Cheers, They sure did. Everything you see from chassis up came in the kit.
Old 01-24-2017, 07:17 PM   #15
I messed up a little and broke a pin off the tailgate so I cut the other one off and hopefully what I've come up with works
Old 01-25-2017, 03:46 PM   #16
Natedog's Avatar
If that's a piece of piano wire, you're good to go. Styrene rod is not very strong in that size.
Old 01-25-2017, 07:05 PM   #17
Close enough, its just a paperclip
Just finished up hitting some thing with semi gloss clear. Not a fan of high gloss
Old 01-31-2017, 10:11 PM   #18
Got a bit more done on the tiny lux lately,
So far I'm mostly done other then lights and wiring but still waiting for LEDs, the floor is now screwed to the chassis in its place and the tub is fitted with half the ESC case (it still fits inside!) and the stock body mount to keep it removable.
I've also glued in glass, mirrors and sliders, glued the mud flaps and flares to the tub panels but the can't be glued on just yet so they're just taped.
And a better shot of the interior, come up better then I expected
Old 01-31-2017, 11:00 PM   #19
Very nice! I just picked up a two-door Toyota body from the same manufacturer, so its nice to see a potential look.
I would paint the bottom of the fenders to match the fender flares as it looks slightly incomplete with a line of yellow underneath the black. Just my .02
Overall, beautiful crawler.,.,.,.
cleanandserenesteve is offline   Reply With Quote
Old 01-31-2017, 11:34 PM   #20
Cheers!
I wanted the two door originally but decided the 4 would be easier interested to see how that goes.
I also thought that and they are drying as I type. Looks much better
Ambush LN107 twin cab - Similar Threads
Losi Trekker becomes Hilux twin cab northernerbill Losi Micro-Rock Crawler 21 09-02-2012 10:56 AM
My Ambush v. CGR GTFO!! OG AMBUSH STATUS kikcaffine Axial SCX-10 5 07-24-2009 07:58 PM
