02-10-2017, 09:20 PM | #1 |
SCALE PERFORMANCE PARTS Join Date: Oct 2007 Location: Cedar Park
| Locked Up's Ambush
"Pan down. I want ......" Oh wait, that's from something else. As a kid, I loved Stompers. Power them up and they drive forever (in kid time) in a straight line. I remember running them down the sidewalks, through streams .... I think I had one that had flotation/paddle tires too?! Anyway, When I saw a deal on a Proline Ambush I snatched it up. I was somewhat expecting an RC version of that Stomper. Something I could drive across the keyboard and terrorize the cat with (but never catch it). Reality set in when I opened the box. The reality that I can't have nice things because of ... me. Immediately upon opening the box my brain started troubleshooting the body mounting, articulation, weight distribution, steering throw. I suspect I'll end up destroying this thing in an effort to make it bullet proof. So, the battery is still charging and here is what I have found so far. 1. These things are small. That is a 1.9 (not yet released - you saw it here first). 2. The body mounting system must be off from the factory. 3. I might be the only one that notices the servo catches on something well before you get to full stuff. |
02-10-2017, 09:30 PM | #2 |
| Re: Locked Up's Ambush
Body seems easy enough to remedy. The mounts are adjustable height and mine was set to zero so the velcro was not catching. Easy fix. Later on I might lower that and trim the body to sit lower. Next I went after the rubbing issue with the servo. After some mild trimming. Not 100% stuffed but better. I also removed the front internal springs because there was very little articulation. I know, I know ... Stompers had zero articulation. I only removed the front because I'm used to a softer front and firm rear... I blame my love of XJs. Yes, you sick bastards go ahead and make that sexual somehow. Ohhh ... the lights are green. Time to play! Last edited by Locked Up; 02-10-2017 at 09:34 PM. |
02-10-2017, 09:37 PM | #3 |
Rock Crawler Join Date: Nov 2009 Location: OKC, ok
and then the bright idea to go to hobby lobby and buy a model truck body for it hit your head....... oh no! lol
02-10-2017, 09:39 PM | #4 |
So lockedup rc micro beadlock wheels and steering links?
02-10-2017, 10:00 PM | #5 |
| Re: Locked Up's Ambush Might have to. Definitely have to find a new wheel nut wrench. I tried to take the wheel nuts off and it stripped out immediately! Last edited by Locked Up; 02-11-2017 at 07:50 PM. |
02-11-2017, 01:42 PM | #6 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
| Re: Locked Up's Ambush |
02-12-2017, 02:19 PM | #7 |
One more poser shot... |
02-13-2017, 03:10 PM | #8 |
Quick video .... https://www.youtube.com/watch?v=vFAAPUumbQ8 Last edited by Locked Up; 02-13-2017 at 03:18 PM. |
02-19-2017, 07:46 AM | #9 |
Small tip, if your going to leave the battery in t he stock location, 1/2oz worth of stick on wheel weights go a long way on the bottom of the cross member th hat the battery box is on. And there's room on the back of the servo for another 1/4oz. It's really helped the front end stay down on mine. Sent from my SAMSUNG-SM-G891A using Tapatalk |
04-16-2017, 08:19 AM | #10 |
Newbie Join Date: Dec 2011 Location: outside
Got any updates for the Ambush Army out there? Sent from my SAMSUNG-SM-G920A using Tapatalk |
Locked Up's Ambush - Similar Threads | ||||
Locked Up's SCX10 II Build | Locked Up | Axial SCX10 II | 120 | 12-07-2018 08:36 AM |
Locked Up's SMT10 | Locked Up | Mega/Monster Trucks | 19 | 07-18-2018 04:05 PM |
Locked Up's Wraith | Locked Up | Axial Wraith | 40 | 02-17-2016 06:32 AM |
Locked Up's XR10 build | Locked Up | Axial XR10 | 60 | 03-06-2011 10:10 PM |
