Go Back   RCCrawler Forums > Scale Rigs General Tech > Micro Scale Rigs
Thread: Ambush - Land Cruiser 80
Old 04-04-2017, 01:23 AM   #1
ElChupoCabre's Avatar
Default Ambush - Land Cruiser 80
Been a while...
Bagged an Ambush, played with it a bit.
I've always wanted a 1:1 LC FJ80 (maybe one day) but, until then...
Contemplated using the chassis from the static model but honestly did not want to go through that much custom fabrication. It has been a while since I have built anything so I wanted to start off easy, and get to play'n with my toy truck. My intention is to use as much from the model as possible and cut as little away from the floor as I can.
Started to fit the tub for the interior tub and size up the body's height etc.
Started to do a little paint for the interior.
Had to get rid of the stock battery. Found this one, only 50mah less than stock but only about 1/3 the size! Fits under hood perfectly.
Magnets for to hold down the hood. (super tiny, about 100ea in this bag!)
Works Great!
Made a scale Hi Lift Jack out of styrene. It will hang from the roof rack later.
In order for interior and body to fit right. I had to lower the skid plate, shave some material from bottom of transmission case to gain about 4mm. Then I shaved about 2mm from the perches that hold the leafs to the axles. With a lil' bit shaved from the floor on the interior's tub I was able to drop the body about .5" from original stance. This greatly improved center of gravity, and improved drive shaft angle from stock. Only lost about 2mm clearance from skid to floor.
Started to mock up some of the scale goodies. Made a Fire Stick antenna out of a piece of wire.
Done. Pics from 1st run.
Later I added some rock sliders, chain on the front bumper and painted the side blinkers.
Made some fake rocks for some couch crawl'n action.
After it dried, I tested it out a bit.
Thanks for looking.
ElChupoCabre is offline   Reply With Quote
Old 04-04-2017, 10:21 AM   #2
Default Re: Ambush - Land Cruiser 80
I think this is my favorite ambush so far! What scale is the Tamiya kit?
soze is offline   Reply With Quote
Old 04-04-2017, 03:03 PM   #3
Nice work, makes me want to resurrect my Ambush
crashradius is offline   Reply With Quote
Old 04-10-2017, 09:50 PM   #4
Thanks guys! I believe that the Landcruiser Tamiya kit is 24th scale.
Old 04-11-2017, 02:17 AM   #5
Wow! That looks great! I wish those had more suspension articulation. They seem so stiff...
excellent job!
cleanandserenesteve is offline   Reply With Quote
Old 04-17-2017, 11:37 PM   #6
Visited my grandfather for Easter... I told him I get 1st dibs! (He got a kick out of the lil' rig that looked like his.)
Old 05-24-2017, 06:16 AM   #7
What did you use for electronics? Noticed the battery isn't the stock one.
06ToasterBox is offline   Reply With Quote
Old 05-29-2017, 03:07 PM   #8
I just used the stock electronics with the exception of the battery. I placed them between the frame rails above the rear axle.
Pretty much in stock location. I removed the plate that it was taped to, then I just drilled two holes in the case on each side. There are screws from the chasis that protrude where the shock towers are mounted. These screws go into the holes in the plastic electronics case and it is pinched and held in place by the frame rails. Still plenty of room for flex. and travel.
Ambush - Land Cruiser 80 - Similar Threads
Land Rover and Land Cruiser Alpha Male Scale Videos! 0 09-28-2015 04:29 PM
15 trucks Offroad: Sniper Land Rover D90 D110 Ford Land Cruiser Trail Finder 2 Dingo boolean21 Scale Videos! 0 08-30-2012 07:48 AM
12 trucks Mudding! Land Rover Honcho Land Cruiser Dingo D110 RSOV Wraith King Hauler boolean21 Scale Videos! 0 07-16-2012 06:27 AM
hard jeep/land cruiser/land rover body IronRC Paint and Body 2 03-02-2008 10:14 PM
