07-03-2017, 07:57 AM | #1 |
Quarry Creeper Join Date: May 2015 Location: covington
| Help mounting tires
Is there an easy way to mount tires on RC4WD 1.0 steel beadlock wheels? Tires are RC4WD Rok Lox.
07-03-2017, 09:21 AM | #2 |
Newbie Join Date: Apr 2016 Location: Somewhere
| Re: Help mounting tires
I have the same wheels and tires, and yes they are a pain to get started evenly. Once I got the first one the rest were a breeze and I even re-did the first because it wasn't perfect. Do you have 2 longer m2 screws to get them started. I don't remember if it came with them or if I had to use some I had. Then get everything all evenly behind the bead up and squeeze it together before putting in the correct length screws.
07-03-2017, 09:31 AM | #3 |
Well i got them mounted up.They fit is good but the quality of the wheel is not what i expected Sent from my LG-H631 using Tapatalk |
07-03-2017, 12:30 PM | #4 |
Pebble Pounder Join Date: Mar 2017 Location: Smyrna
I found gluing the hex part on the back makes things a lot easier Sent from my SAMSUNG-SM-J320A using Tapatalk |
07-03-2017, 01:52 PM | #5 |
Pebble Pounder Join Date: May 2017 Location: Covington
I had awful installation problems too. I asked RC4WD to send me a set of longer wheel screws. They did so. These were able to reach all the way through to secure the two sides of the wheel. I used half the long screws and half the short screws (that comes with the wheels). Once I started with the long screws, each wheel only took 5 minutes or so. Good luck.
Help mounting tires - Similar Threads | ||||
mounting tires with beadlocks | Shredder | Axial AX-10 Scorpion | 3 | 09-07-2008 11:02 PM |
mounting the tires | 25-5 | Axial AX-10 Scorpion | 12 | 10-12-2007 03:07 PM |
mounting tires | clodhelpneeded | Newbie General | 5 | 08-28-2006 09:47 AM |
mounting tires | andrewmp6 | Newbie General | 1 | 05-07-2006 01:12 AM |
