08-17-2017, 10:54 PM | #1 |
Pebble Pounder Join Date: Mar 2014 Location: Australia
| Orlandoo Hunter Alloy Shock Fix
Have you recently upgraded to the stronger alloy shocks and noticed its bouncing all over the place and flops around? I have a fix for you.... First off the springs are to long... using a cut off wheel remove 2 coils from the springs (now the preload adjuster can be used to set rideheight and are not just for looks ) next... the rear springs are to soft and offers little stability my advice is to fit the optional 1.5 springs to the rear but dont forget to remove 2 coils like before and using the preload adjuster to set the ride height Now for turning these fancy spring holders into shocks.... all fixed... the shocks just needed a drop of Losi 7000wt oil each 1-Remove shocks from vehicle 2-remove top cap, (careful not to take of the spring adjuster, its a pain to get back on) 3-compress shock and get ready with a drop of 7000wt oil 4-as u place a drop, slowly uncompress the shock so it sucks the oil in 5-cover the top with ur finger and cycle the shock a few times 6-fully compress the shock and wipe away excess oil 7-refit the cap and its good to go After reassembly, if the shock is excessively stiff. repeat steps 6-7, it only needs a tiny tiny bit... rather than using silicon oil as a hydraulic limiter, in this setup its used to make everything a little bit "sticky" to slow down the action, and the reason for the really thick oil is because these shocks dont have a o ring so anything thinner might leak out Before [youtube]https://www.youtube.com/watch?v=uEPNY0-nRpg[/youtube] https://www.youtube.com/watch?v=uEPNY0-nRpg After [youtube]https://www.youtube.com/watch?v=Kvss5sEWhQA[/youtube] https://www.youtube.com/watch?v=Kvss5sEWhQA Last edited by Phmaximus; 08-18-2017 at 03:46 AM. |
11-01-2017, 05:31 PM | #2 |
Quarry Creeper Join Date: Dec 2016 Location: Womelsdorf
| Re: Orlandoo Hunter Alloy Shock Fix
Thank you! Keep the Landoo tips coming |
Orlandoo Hunter Alloy Shock Fix - Similar Threads | ||||
My Orlandoo Hunter Rubicon | ywwong135 | Micro Scale Rigs | 18 | 02-13-2017 06:17 AM |
Gmade R1 vs Orlandoo Hunter | rc2000 | G-Made Crawlers | 1 | 12-25-2016 09:22 PM |
Orlandoo Hunter (jeep) | THUD | Newbie General | 3 | 12-23-2016 10:29 PM |
Orlandoo hunter | wheatyman | Micro Scale Rigs | 8 | 08-13-2016 10:36 AM |
my Orlandoo hunter build | eypontwion | Micro Scale Rigs | 1 | 08-06-2016 10:26 PM |
