02-25-2018, 09:06 PM | #61 | |
Rock Crawler Join Date: Jun 2015 Location: In the Sticks in the Ozarks
| Re: Getting Small...ER , Orlandoo style Quote:
He just had a few of them listed, I just got lucky. If you're an ebayer, shoot me a pm and I'll give you his seller ID and you can try to contact him for more info, if he's still active, that is. I can give you measurements for mine if that'll help any. | |
02-26-2018, 01:24 AM | #62 |
Newbie Join Date: Dec 2016 Location: British Columbia
Well I ordered up THESE to test out. Can cut them in sections of 3LED's. By quick calculations I think the width I need will fit 6 led's wide and work. If they dont turn out maybe i'll contact the guy you got yours from.
02-26-2018, 08:21 AM | #63 |
Mine is 40mm x 3mm, the case is 43mm x 4mm, the lead end adds a couple mm. Mine has 19 smd's, I think they're 0402's, maybe 0603's. |
02-27-2018, 05:03 AM | #64 |
Pebble Pounder Join Date: Jun 2015 Location: Netherlands
Love your build! Still stuck with mine on getting those small SMD LEDs to stay in their place... |
02-27-2018, 10:03 AM | #65 | |
Yep, one of the toughest parts of the build, for my old eyes. That's one reason I body-mounted mine, so I can work on the chassis without dealing with the little bastards. You'll get 'em. Then post up and show us your rig. | |
03-19-2018, 02:04 PM | #66 |
Rock Stacker Join Date: Apr 2013 Location: usa
Do these kits come with the motor and esc? They look awesome!
03-19-2018, 02:22 PM | #67 |
| Re: Getting Small...ER , Orlandoo style Nope, you can find kits bundled with them, but you still choose what gear ratio you want, usually, and there are a few to choose from. The ESC for these run the steering servo and lights too. You'll need a 3-ch radio set for the lights, and receiver size is a bit tricky. I'm using a Traxxas rx, but I had to "compact" it as much as possible. They're a challenge, but a really fun build, so I'd recommend 'em. Just be ready for SMALL parts and assemblies. You'll see it said in a few threads for these, magnifying glasses are a big plus. And I built most of mine over a silicone mat, it helps keep up with dropped screws. Get one, and share the build with us, here. And Thanks for lookin'. |
03-25-2018, 07:42 PM | #68 |
Well, the weather is still too bad to try the new tires on the F-100, so I decided to start another little project for the Yeep. I got out the evergreen 2-mm I-beam and the pin-vise and did this ... .... so that when I got the sheet styrene out and made the other parts, like these ... ... they will go together and look like this. It's still a work in progress (I can only handle so much of the micro' stuff at once), and it's not perfect, but I'll post up some more pic's as I finish it. |
03-26-2018, 06:13 PM | #69 |
RCC Addict Join Date: Feb 2016 Location: Princeton, North Carolina, USA
| Re: Getting Small...ER , Orlandoo style Quote: That looks pretty cool though. Now I want to see a scale driver and a camping trailer! Sent from my SM-G930R4 using Tapatalk |
03-26-2018, 09:56 PM | #70 | |
Anyway, here's the latest .... I got the handle parts made, drilled the base, cut some sewing pins for the pivots and a couple of N-gauge RR spikes for the ratchets. Got it assembled too. I still need to make the cleat for the top, and paint it. It's functional, except no automatic ratchet. I used a craft needle for the handle. I didn't even attempt to make working ratchets .... ... but the pins in the "faux" ratchets slide in and out, so it is adjustable. It's just small styrene I-beam, so it doesn't like it, but it will hold up the Yeep ... for a minute. Now I need to get it hung on her, somehow. It'll be tricky to paint it without getting too much on it .... eeeasy with the air-brush. Last edited by dr frankenstyle; 03-26-2018 at 09:58 PM. | |
03-27-2018, 06:46 PM | #71 |
| Re: Getting Small...ER , Orlandoo style |
03-28-2018, 09:08 PM | #72 | |
| Re: Getting Small...ER , Orlandoo style Quote: Sent from my SM-G930R4 using Tapatalk | |
03-29-2018, 09:40 AM | #73 |
Now that I see it on the big screen, that's really cool! Nice job!! Now paint it red and strap it on |
03-29-2018, 10:08 AM | #74 | |
03-30-2018, 01:45 PM | #75 |
Ok, I decided, all on my own, to paint it .... ... kinda red, well, dark red anyway. But even airbrushing thin coats, the paint still stuck the slides to the rail .... so it's no longer is functional. Not like it was gonna get used anyway. It should make a decent add-on. Now I gotta make some hangers. Last edited by dr frankenstyle; 04-01-2018 at 07:49 PM. Reason: DOH!! |
04-01-2018, 08:00 PM | #76 |
OK, I cut a couple of triangles from the .060 styrene and drilled them for sewing pins. Then I welded them (with 5-min epoxy ) to the rack .... ... and painted 'em flat black to match. Then with a little black thread as rope, I tied the handle to the rail, and the rail to the rack. It fits nicely, out of the way, but handy if you need it. No interference with any doors, and doesn't take up any cargo space. Me like. Oh, and I scaled-down the spare tire spinner too, in case nobody noticed. |
04-03-2018, 01:04 PM | #77 |
08-21-2018, 07:49 AM | #78 |
Newbie Join Date: Aug 2018 Location: US
Very nice build. You have given me several ideas on how I can mod my orlandoos. But how did you make the shackles and the bits for the hi-lift jack? ...Like what materials and technique did you use?
08-23-2018, 08:28 AM | #79 |
| Re: Getting Small...ER , Orlandoo style Thanks I made the shackles from scrap pieces of aluminum. I used "jewelers" files (they're pretty small) and a small vise, to file them into shape. Then I cut sewing pins to hold them on. I think I have more pic's of the process, if you want to see more. The jack is made of styrene. I used different thicknesses for the different parts, and I drilled a piece of I-beam for the main shaft. I added metal pins and such too. Like the shackles, I think I have more pic's of the jack build. Nothing magic about it, if I can do it, anyone can. I don't have high-tech machinery, it just takes a little time. |
08-23-2018, 10:42 AM | #80 | |
Sent from my XT1585 using Tapatalk | |
Tags |
oh35a01, orlandoo jeep |
Getting Small...ER , Orlandoo style - Similar Threads | ||||
New Orlandoo | Joostproost | Micro Scale Rigs | 1 | 09-07-2016 10:48 AM |
