06-04-2023, 01:37 PM | #1 |
Newbie Join Date: Sep 2017 Location: California
| Scx24 JLU Drive shaft, Axle Question
I have a scx24 JLU Jeep, I upgraded the servo holder and servo. The chassis link Connects to the servo holder. It was rubbing on drive shaft. I took the axle apart and the worm drive gets stuck, going backwards. Could it be the bearings that are uneven now. Should I just buy a new front axle ? This problem burned my stock motor up too.
06-04-2023, 02:13 PM | #2 |
Pebble Pounder Join Date: Apr 2023 Location: NW Connecticut
| Re: Scx24 JLU Drive shaft, Axle Question
You could buy new bearings , there are also usually 2 small O rings used as shims on the worm gear that may have worn out .Get rid of that triangle link and 4 link the front upper link so it doesn’t rub again . After market link sets with the triangle are designed to clear the driveshaft.The front upper links are 39mm eye to eye . You may have gotten them in the extra parts bag . I’m working on a JLU for my wife . Let me look at my extra parts bag .
06-04-2023, 02:27 PM | #3 |
Well I measured my spare parts bag links they are front lower and rear lower links .
06-04-2023, 02:37 PM | #4 |
Newbie Join Date: Jul 2022 Location: Linköping
Partsbags have been different on all my scx24, no links at all for my C10.. hope you solve your problem! Skickat från min SM-G525F via Tapatalk |
Scx24 JLU Drive shaft, Axle Question - Similar Threads | ||||
Scx24 Center Drive Shaft | 91300zx | Micro Scale Rigs | 4 | 08-21-2021 10:39 AM |
3 wheel drive SCX24- Lost axle pin | surfishjoe | Micro Scale Rigs | 7 | 05-03-2020 06:30 PM |
Scx24 front axle half shaft binding in drive cups | Ho11owPoint | Micro Scale Rigs | 6 | 05-02-2020 01:30 PM |
SCX24: Deadbolt Vs JLU | KulaHI | Micro Scale Rigs | 13 | 01-08-2020 05:21 PM |
best way to join a rwvo drive shaft to the output shaft on the axle | TRAV | Kyosho Crawlers | 12 | 01-29-2012 07:37 PM |
