12-18-2017, 05:50 AM | #1 |
Newbie Join Date: Feb 2015 Location: unknown parts
| Orlandoo Hunter Jeep Help
Curious if anyone has picked up part MA2-550... the aluminum axles. Picked them up and there are no instructions with them. Found a single page online on how to assemble them but the geometry is all wrong when i try to install on the chasis. No room the way the steering servo is mounted and the axles don't sit properly. All the links seem to be messed up lengths now. Has anyone successfully installed these and care to share the solution or some pics? Thanks Sent from my SM-G935W8 using Tapatalk |
12-18-2017, 06:15 AM | #2 |
Quarry Creeper Join Date: Dec 2016 Location: Womelsdorf
| Re: Orlandoo Hunter Jeep Help
I don't have one but I would start off by ordering a few link kits. The kits are cheap and will allow you to change/dial in your suspension and wheelbase..
12-18-2017, 06:42 AM | #3 |
Pebble Pounder Join Date: Feb 2015 Location: Cambridge, UK
If you're using them on the F-150, you will need the upodated link kit: https://www.banggood.com/Orlandoo-F1...r_warehouse=CN Also make sure that you line up the shafts correctly, you need the screws in-line with each other so they don't bind... |x|------=====|x|-|-|x|=====------|x| I also have the male end on the axles and female on the gearbox. I also had the Jeep with metal axles, and all was fine - you just need to make sure your links are set correctly. Last edited by jimbo_wa; 12-19-2017 at 07:52 AM. |
12-19-2017, 01:24 PM | #4 | |
| Re: Orlandoo Hunter Jeep Help Quote:
The front axle also came with a mounting holder for the steering servo but you can't use it as it binds with the frame and shocks... i was a bit dissapointed with that but what can you do. Sent from my SM-G935W8 using Tapatalk | |
12-20-2017, 02:36 AM | #5 |
Newer Jeep = Pajero? The SWB Jeep with the full metal axles has definitely been done by others, (I know that they're wider than stock) but not sure what link lengths were correct I'm afraid... Putting the servo on the chassis is a good mod for the Jeep and easy to do too. |
12-21-2017, 01:42 AM | #6 |
Pebble Pounder Join Date: Mar 2014 Location: Australia
yeah, unfortunately they are not intended for the Jeep and in stock configuration limit the suspension ever so slightly and like u noticed the links are now wrong. IMO stick with the stock axles... but........ it can be corrected. with a custom chassis mount servo u should get the suspension travel back and I cant remember what links to use, but they are cheap... just order them all (f150,jeep,pajero) |
Orlandoo Hunter Jeep Help - Similar Threads | ||||
My Orlandoo Hunter Builds Ford, Jeep , 6x6 Freightliner | Phmaximus | Micro Scale Rigs | 120 | 02-20-2019 08:26 AM |
Orlandoo Hunter OH35A01 Jeep Build | soze | Micro Scale Rigs | 13 | 04-16-2017 10:15 AM |
Orlandoo Hunter (jeep) | THUD | Newbie General | 3 | 12-23-2016 10:29 PM |
