01-04-2018, 07:55 PM | #41 |
Rock Crawler Join Date: Mar 2009 Location: Parker, CO
| Re: ECX Barrage upgrades
Anybody know what voltage the stock ESC puts out to the LED lights?
01-04-2018, 08:05 PM | #42 | |
I wanna be Dave Join Date: Feb 2007 Location: South FL
| Re: ECX Barrage upgrades Quote:
Sent from my SM-N900T using Tapatalk | |
01-04-2018, 08:39 PM | #43 | |
Rock Crawler Join Date: Jan 2008 Location: Lehigh Valley, Pa
It’s 64 teeth. Sent from my iPhone using Tapatalk | |
01-04-2018, 09:05 PM | #44 |
64T spur 12T pinion 24T ring gear I believe 12T pinion. I counted all the gears in the transmission, but the info didn't seem to save so I'll count them again soon. Fwiw the sumo axles are very similar in dimensions and have the same 24T ring gear, however with a 13T pinion that doesn't swap between the ECX. Sent from my SM-N900T using Tapatalk |
01-04-2018, 10:32 PM | #45 |
Quarry Creeper Join Date: Nov 2017 Location: Ulaanbaatar
| Re: ECX Barrage upgrades |
01-05-2018, 08:25 PM | #46 | |
| Re: ECX Barrage upgrades No, I have several. Im just lazy. Quote:
As it turns out, those little leads coming off the stock brick are putting out full pack voltage! So I made a double pigtail out of them to plug in to a proper Rx. I assume the extra lead is for a future light bar or something. I really like the design of this chassis. This truck performs (mechanically) as good or better than a Trekker IMO. | |
01-05-2018, 09:40 PM | #47 |
| Re: ECX Barrage upgrades Quote: Thanks, MP |
01-05-2018, 09:42 PM | #48 |
01-05-2018, 10:19 PM | #49 |
Rock Crawler Join Date: Apr 2006 Location: Folsom, CA
Hitec 65MG fits perfectly, just installed mine. Works a lot better than the stock junker too. Where can I get pinions for this motor? Or buy a motor that is a lot slower than this one? I want to be able to crawl it easily |
01-05-2018, 11:17 PM | #50 | |
https://www.ebay.com/itm/ARP-8-Tooth...97.m4902.l9144 | |
01-06-2018, 10:16 AM | #51 | |
Also, be carefull of the 8tooth brass .3 Mod gears. They are very thin and snap under load easy. I stick with 9t at minimum for brass. If you can find nylon or acetyl 8t in .3 Mod, please let me know Last edited by Shape_Shifter; 01-06-2018 at 10:31 AM. | |
01-06-2018, 07:51 PM | #52 |
Rock Stacker Join Date: Apr 2017 Location: RI
Anyone found a solution for our non dampening too stiff springs yet? Just got mine in and noticed they are horrible lol. Also my god the dam torque twist. Turning right at full speed is futile.
01-06-2018, 08:49 PM | #53 |
| Re: ECX Barrage upgrades You could dampen the stock ones with thick grease. Im going to try the Hot Bodies micro shocks. They have some slight friction dampening.
01-06-2018, 09:00 PM | #54 |
01-06-2018, 09:10 PM | #55 |
Even then the springs are way to stiff even if you dampened them. You cant get the full travel out of them :(
01-06-2018, 09:21 PM | #56 |
| Re: ECX Barrage upgrades I cut 3 coils out of the rear shocks and 2 coils off the front and it sits a lot lower. Quite a bit more stable too. The front travel is limited by the drag link hitting the frame on the driver side. Been thinking about putting a little bend in it to clear the frame at full flex.
01-06-2018, 09:23 PM | #57 |
If you have torque twist turn down the dual rate on your steering. Mine didn't have any problems with twist right out of the box Sent from my SM-N900T using Tapatalk |
01-06-2018, 09:24 PM | #58 |
Also the hot racing shocks are pretty horrible. It's known they are very stiff and don't perform well. Sent from my SM-N900T using Tapatalk |
01-06-2018, 09:26 PM | #59 |
Can you tale the shock bodies apart? If so, put a small piece of open cell foam in there then fill the rest with the thickest axle grease you can find. basically your trying to make a constant friction inside. I dont know if these shocks can even be modded.
01-06-2018, 10:09 PM | #60 |
You could but that doesnt help with the fact that the springs are too strong. Im going to try to get them measured and find a way to figure out how strong they are so we can get something softer.
ECX Barrage upgrades - Similar Threads | ||||
Best First Upgrades - ECX Barrage | Mancub | Newbie General | 89 | 05-16-2018 06:44 AM |
Ecx barrage trail armor upgrades | nerby149 | General Scale Talk | 3 | 01-23-2017 12:46 PM |
ECX barrage | Cpyonker | General Crawlers | 7 | 12-21-2016 09:18 PM |
