Go Back   RCCrawler Forums > Scale Rigs General Tech > Micro Scale Rigs
Thread: FTX Outback MINI 1/24 Scale truck review & build
Old 05-03-2018, 07:54 AM   #21
Default Re: FTX Outback MINI 1/24 Scale truck review & build
Originally Posted by Brake Weight View Post
Finland..!?!! I’ll just keep mine.
I'm still open for trade! ;)
I was not comfortable with the original "Rhino"-type of grille of the Tonka and wanted something what is more familiar to me. As I live here where I do, Wagoneers are not very common tough many of them have been brought here afterwards but mostly late 80's and 90's versions.
I wanted to test if I can achieve a later 60's look..
First to make is the grille part of the grille.. printed it out negative to make it easier!
Oh noes I made a mistake. Where is the CRTL-Z here? I want to undo!
Supports for the grille with some shape on them. Forex that is! or Komacell!
..came out too steep, needed to fix the angle of the upper part. On the right side you can see the bent piece of styrene what will go between the grille piece and the supporting parts.
Headlight frames from PVC-panel. Drilled a 10mm hole and then carved it to shape with half-spherical file. Fun, actually! Thats why I did it few times to get it near.. ahem.. right?
Here is what I do with most of my parts what need to be duplicated. I glue them together and file them to approximately same size.
Grillin'
"You can try the best you can, you can try the best you can. Best you can is good enough." ;)
Far from perfect but perhaps close enough for this vintage body what is not perfect either! Let me know if you dislike it.
Best regards, Heikki.
Halme is offline   Reply With Quote
Old 05-03-2018, 08:02 AM   #22
Looks far better than the original! Great job!
R.Billy Rob is offline   Reply With Quote
Old 07-01-2018, 02:39 PM   #23
wow very nice job
losigod is offline   Reply With Quote
Old 05-07-2019, 10:48 AM   #24
That's a sweet truck, what are some of the future upgrades you have planned?
bignheavy1007 is offline   Reply With Quote
Old 05-08-2019, 09:06 PM   #25
Grillin'
Did you ever end up modding any of the internals? What all did you do? Very nice build man. You make it hard to decide what to get for a Micro
Old 05-09-2019, 08:26 AM   #26
WOW!!!What a build!!!I far from "dislike"lol.
bolo79 is offline   Reply With Quote
FTX Outback MINI 1/24 Scale truck review & build - Similar Threads
RGT rock cruiser and FTX outback Cpyonker General Crawlers 3 11-15-2017 01:31 PM
Ftx 1/24 outback mini scale crawler MattTheGenus Micro Scale Rigs 21 11-10-2017 04:30 PM
Honcho Wooden Truck Bed Build & Scale Drive DWJL511 Scale Videos! 2 07-29-2015 06:58 PM
my review on a good budget esc for a scale truck Matty221133 Electronics 0 06-26-2014 04:47 PM
dpdsurf's XR10 Build & Review dpdsurf Axial XR10 32 11-08-2010 11:44 AM
