01-12-2018, 02:08 PM | #1 |
Rock Stacker Join Date: Apr 2017 Location: RI
| Noobs first build. ECX Barrage 1/24.
This is my first Hobby grade rc and I come from mostly real life car modding. I figured I may have some things that I do to my rc that other people might not have thought about so I figured I would post my build. Pics and stuff are soon to be coming in. Parts List: SG92R Micro Digital Servo 2.5kg Fast Eddy Bearing Kit Modifications: C-hub nub shaveThe nub you see is what it starts out as. I filed it flush. Its probably like 2-3 degrees in either direction of additional steering angle. 2s Lipo (Eventually. I want to get a new ESC/TX/RX before) 180 Tranmission. Credit goes to User Moondaddy who I believe did i first. If you 180 the transmission the motor wires do not reach the receiver so I relocated it on top of the servo. Once you do that the body posts are not long enough. I decided I wanted a different front body anyways so it was no big deal. Alternatively you could get longer body posts in the front to clear it. Part Reviews: SG92R servo. Its ok. You can not find the specs for the stock servo anywhere. After installing this one I am going to guess the stock one is in the 1.7-1.9kg range. This upgrade is somewhat worth it but I think I will upgrade to the 5kg Savox Servo Next. Last edited by Heroesneverquit; 01-24-2018 at 08:24 PM. |
01-17-2018, 09:21 PM | #2 |
| Re: Noobs first build. ECX Barrage 1/24.
Put in the fast eddy bearing kit. For anyone looking to do this upgrade its not too bad. The front axle bearings on the differential can be a pain to get off. The pins on the end slide out of the way but are very stiff and hard to move. I slide them out halfway and just slid the bushings/bearings over that way. Removing them all the way may be possible but I wouldnt want to try it. Its 7 in the front axle, 3 in the rear, and 8 in the transmission if my memory serves me right. When doing the difs there is one behind the gear that comes off the drive shaft. I did not notice this the first time around and had to disassemble the axles... again. The transmission gears also only fit into the box in one way.
01-18-2018, 10:45 AM | #3 |
Rock Stacker Join Date: Jan 2009 Location: Carthage
Informative post. Thank you sir.
01-26-2018, 07:53 PM | #4 |
Fit a new body from revell on. Trying to figure out how to secure the front down though.
01-27-2018, 04:45 AM | #5 | |
Quarry Creeper Join Date: Mar 2014 Location: san antonio
| Re: Noobs first build. ECX Barrage 1/24. Quote:
I used a revell model as well on mine. I just drilled holes in the hood for the body pots to come through. Not the most scale looking option but the next one I build up I’ll take some more time and mess with some styrene and magnets to hold the front and rear down if I ditch the honcho style rear section. Sent from my iPhone using Tapatalk | |
02-28-2018, 12:43 AM | #6 |
Newbie Join Date: Feb 2016 Location: c-well
| Re: Noobs first build. ECX Barrage 1/24. |
08-06-2018, 09:23 PM | #7 | |
Was this a 1/24 Revell? | |
11-26-2018, 11:42 AM | #8 |
| Re: Noobs first build. ECX Barrage 1/24. My barrage is actually broken right now and has been for quite some time. Everytime I got it working some thing new broke, its always the electronics though. Probably because I was cheaping out. I can get you a picture of it with the body on but my painting looks like garbage and I never got around to painting the hood lol.
Noobs first build. ECX Barrage 1/24. - Similar Threads | ||||
1st Hobby Grade RC, ECX Barrage 1.9 Build | 220shaun | 1.9 Scale Rigs | 17 | 08-16-2017 12:38 AM |
ECX Barrage, A noobs attempt at scale crawling | Pilot_MM | Videos! | 1 | 01-04-2017 11:45 PM |
ECX barrage | Cpyonker | General Crawlers | 7 | 12-21-2016 09:18 PM |
ECX Barrage 1/12 for husbands bday build/questions | Mirmirshay | Newbie General | 7 | 11-15-2016 01:28 PM |
