Go Back   RCCrawler Forums > Scale Rigs General Tech > Micro Scale Rigs
Thread: Wpl c24
Old 11-12-2018, 10:49 PM   #41
Default Re: Wpl c24
Originally Posted by PileDriver View Post
Those CVD looking ones. What do they go to originally?
Brake Weight is offline   Reply With Quote
Old 11-12-2018, 11:15 PM   #42
Default Re: Wpl c24
They are made for the wpl models. I got em from Banggood.
PileDriver is offline   Reply With Quote
Old 11-13-2018, 03:42 AM   #43
Default Re: Wpl c24
All this c24 talk has motivated me enough to order one. I built a c14 last year on Losi Mini axles and have yet to use it aside from the initial battery pack testing. Ima order a c24 now and the bits to swap it over to leaf springs and metal gears. Something a little different.
Old 11-14-2018, 01:25 AM   #44
Default Re: Wpl c24
That'll be sweet. When ordering the metal gears make sure to get black gears as they are steal not brass.
Old 11-14-2018, 05:27 PM   #45
Default Re: Wpl c24
Waiting on the $47cdn original upgrade pack don't think the brass ones are that bad.
chbronco is offline   Reply With Quote
Old 11-14-2018, 06:25 PM   #46
Default Re: Wpl c24
brass ones aren't to bad. steel is just stronger and id rather screw into steel than brass with those little set screws.
Old 11-15-2018, 01:58 PM   #47
Default Re: Wpl c24
Yes true.
Sent from my SM-G955W using Tapatalk
Old 11-16-2018, 02:57 PM   #48
Default Re: Wpl c24
Man, browsing these WPL threads just made me order a c14 and c24 + upgrades for both.
soze is offline   Reply With Quote
Old 11-16-2018, 03:45 PM   #49
Default Re: Wpl c24
I’ve got a c24 ordered as well new axles already fitted with the brass gears. Also some spare leaf springs and I’ll rob the leaf mounts off of my unused B-1. Now the wait game....
Old 11-16-2018, 06:23 PM   #50
Default Re: Wpl c24
Sweet, I can't wait to see your leafy build. I just ordered some rod ends and new shock towers they just came out with.
Old 11-17-2018, 06:00 AM   #51
Default Re: Wpl c24
I went ahead and ordered up one of the C channel chassis’ with the upper leaf mounts and cross bracing. I don’t see any team on these small rigs to need all the aluminum bits they’re selling. So all I’ll need to rob are the leaf to axle mounts from my B-1.
Old 11-24-2018, 10:27 AM   #52
Default Re: Wpl c24
Unfortunately my order has been showing processing for over a week now. This is the only problem with these cool little trucks.
Old 11-24-2018, 11:35 AM   #53
Default Re: Wpl c24
LOL. Here’s where mine are.
Old 11-24-2018, 11:43 AM   #54
Default Re: Wpl c24
Haha. At least yours “shipped”.
Old 11-24-2018, 11:50 AM   #55
Default Re: Wpl c24
Old 11-25-2018, 01:49 PM   #56
Default Re: Wpl c24
Where do u order from?
Old 11-25-2018, 03:23 PM   #57
Default Re: Wpl c24
From BangGood and GearBest. Whomever has the best prices. GBest used to take longer but now they’re about even. Always pay the little extra for insurance and slightly faster shipping. Otherwise it’s a cargo ship from China instead of a plane ride.
Old 11-28-2018, 10:05 AM   #58
Default Re: Wpl c24
Got me one C24 too. I just looove that sleeper cab.
The terrible bump-steer was the only thing that bummed me out for a bit. The rest of the kit was a pleasant surprise, including only 1 wrong part in the bags : no left rear light cover, only 2 right side ones :P . Frankly, I expected much worse from China stuff. The thing is juuust short of hobby-grade. WPL ìs getting there, though.
I also discovered that the drive shafts’ slider sleeves towards the axles are a bit too long, and bind everything up. Could explain why so many people broke them. The couplings were put under quite a bit of strain. I cut off about 1.5 mm, and now everything runs smooth and free. Just have to shim the pinions for a bit. They rattle because they tend to get pressed away from the ring gear on the spool. Minor problem.
I run it with an ancient 27mhz Atech esc-rx controller from a long-gone Leo-X monstertruck. It juuuust fits under the bonnet. Made a fake CB antenna-mount to fit the 27mhz aerial. Looks nice.
I’m not planning on going the Rolls Royce way like the OP did. Maybe just metal spools and pinions.
The JJrc MAN KAT1, ( still on the slow boat from China, sadly) however, is going to get the 2 speed, steel shafts and gears, oil shocks, full lighting, sound, the works. Maybe even go 8-wheeler, since complete axles and rims are cheap as chips.
Jay-Em is offline   Reply With Quote
Old 11-28-2018, 10:31 AM   #59
Default Re: Wpl c24
Mine is still "Processed through Facility" in Shanghai as of 11/25
Old 11-28-2018, 12:48 PM   #60
Default Re: Wpl c24
Blargh!
Sometimes the slow boat from China seems to have slow rowers on board.. especially when ordering from Gearbest. Banggood is usually relatively quick, say 10 days to the EU, to the States sometimes even as quick as 5 days.
Gearbest on the other hand? 2 to 3 weeks is not unusual.
I dó know You are going to love them. The WPL’s are real nice toys to tinker with. And their small size means that “the other half” usually doesn’t complain as loudly compared to hauling, say, a Bruiser on the kitchen table..
Wpl c24 - Similar Threads
WPL C14 Brake Weight Micro Scale Rigs 633 01-07-2022 02:57 PM
WPL B-1 Brake Weight Micro Scale Rigs 73 07-12-2019 09:53 AM
2 new Wpl trucks seedburns Micro Scale Rigs 4 06-20-2018 05:59 AM
Wpl b-16 MGCrawler Micro Scale Rigs 0 05-05-2018 07:10 PM
