11-05-2018, 03:08 PM | #21 |
Newbie Join Date: Nov 2017 Location: USA
| Re: Latest WPL 1/16
Is it 1/12 scale or 1/16? Sent from my iPad using Tapatalk |
11-05-2018, 04:03 PM | #22 |
| Re: Latest WPL 1/16 |
11-06-2018, 02:09 PM | #23 |
| Re: Latest WPL 1/16
Dang, lotsa cool stuff and the video was entertaining and hilarious! |
11-06-2018, 03:18 PM | #24 |
| Latest WPL 1/16 Last edited by Brake Weight; 11-06-2018 at 03:54 PM. |
11-06-2018, 03:35 PM | #25 |
| Latest WPL 1/16
Aaaaaaannnnnnddddd another. A Willy's this time. https://www.banggood.com/SUBOTECH-BG...p-1376427.html Last edited by Brake Weight; 11-06-2018 at 03:55 PM. |
11-07-2018, 07:23 AM | #26 | |
Rock Crawler Join Date: Jan 2012 Location: Champlin, MN
| Re: Latest WPL 1/16 Quote: https://www.banggood.com/WPL-B36-Ura...r_warehouse=CN I don't know what the argument between them are, but I'd think the B36 with the more traditional setup would perform better than having each axle on it's own leaf no? | |
11-07-2018, 07:42 AM | #27 | |
Never noticed that. I would speculate that the latter would perform better but it appears to be substantially heavier. | |
11-07-2018, 08:58 AM | #28 | |
I do wish however that design was standard on all 6x6 trucks. I'm looking at a 4x4 M35 and was trying to 3d print the parts to make it a 6x6. but it uses plastic gears.. here a RTR 6x6 with metal gears is readily available for only $62ish USD. almost seems easier at these prices to just buy the truck and switch the bodies on them! Honestly I wish there were more metal in the whole drive train on ALL their platforms. I've got two WPL's and both of them broke driveshafts in about 15-20 seconds, and on a 180 motor my Toyota 4x4 blew up the rear axle gear pinion within 5 minutes. I just picked up an stock kit orlandoo crawler and am thinking the same thing may happen once I really start to drive it! | |
11-07-2018, 01:58 PM | #29 |
Pebble Pounder Join Date: Oct 2018 Location: Dayton
| Re: Latest WPL 1/16
Are these even worth messing with for being 58..?? tgis lools really dope & im debating just trying it out. Sent from my iPhone using Tapatalk |
11-07-2018, 02:06 PM | #30 |
| Re: Latest WPL 1/16
Honestly, probably now. Most all the drivetrain is plastic and needs their metal upgrades. I put a set of Losi Mini axles under the Toyota looking one and it’s OK at best. Mostly to look at.
11-07-2018, 02:22 PM | #31 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
| Re: Latest WPL 1/16
How much are the replacement metal axles? Are they complete? Sent from my LGMP450 using Tapatalk |
11-07-2018, 04:03 PM | #32 |
| Re: Latest WPL 1/16
I don’t expect it to be hobby grade, but is it worth the 59.00?? I customize Playmobil for my gijoes but it’s twice the price & I doubt this is worse. Sent from my iPhone using Tapatalk |
11-07-2018, 06:02 PM | #33 |
| Re: Latest WPL 1/16
I’d say it would be worth it. I’ve got the Yoder, GAZ, and that Deuce.5. They’re as cheap as any static model you’d find but bigger.
11-08-2018, 04:23 AM | #34 | |
I just want to add to my fleet. I custom made these two, but the WPL takes it to a different level & cheaper. Sent from my iPhone using Tapatalk | |
11-08-2018, 06:43 AM | #35 | |
All metal axles, but they're square. https://www.banggood.com/Titanium-Co...p-1263706.html Or you can do just the gears. https://www.banggood.com/WPL-Metal-G...p-1296355.html 6x6 gears. https://www.banggood.com/WPL-6X6-All...p-1321928.html This potential jewel is back in stock for now. https://www.banggood.com/WPL-Upgrade...p-1342326.html Driveshafts, leaf spring mounts, pretty much anything they could do in aluminum has a replacement for it now. https://www.banggood.com/search/wpl-parts.html | |
11-08-2018, 07:04 AM | #36 |
| Re: Latest WPL 1/16
Here's another M35. It has some different body nuances and one review/question/answer states that it is slightly larger than the WPL and has 6mm axle hexes. https://www.banggood.com/MZ-YY2003-2...p-1341761.html |
11-08-2018, 11:20 AM | #37 | |
And I pulled the trigger on the B36 sure it's about $60. but it's rtr, with metal gears included. upgrading a plastic model brings the price up to that range pretty quick. Also ordered up some metal drive shafts while I was at it. I don't plan to keep the stock power plant in this toy very long! and for anyone looking into these, I absolutely feel like getting metal gears is a must if you plan to run anything over a 130 motor.. or drive aggressively.. or plan to do much of anything with it past your kids paying in the dirt outside. going full metal is even better, but I don't personally feel it's necessary unless you plan to really push these trucks. frankly I'm upset at how weak the driveshafts too. snapped one just running on carpet in a few minutes on a 180 motor. and that was just a 4x4 Toyota. Got a thread or link to more of those Bruder conversions for the larger trucks? I've seen a few of the 4x4's but haven't seen how people have set up their semi's and other larger 6x6 trucks. | |
11-08-2018, 11:26 AM | #38 |
| Re: Latest WPL 1/16
I looked for a little while for some specs on that MZ brand one. I’m thinking a set of Mini axles would fit underneath it.
11-08-2018, 03:39 PM | #39 |
Pebble Pounder Join Date: Dec 2007 Location: canada edmonton alberta
11-08-2018, 04:06 PM | #40 |
Latest WPL 1/16 - Similar Threads | ||||
WPL B-1 | Brake Weight | Micro Scale Rigs | 73 | 07-12-2019 09:53 AM |
2 new Wpl trucks | seedburns | Micro Scale Rigs | 4 | 06-20-2018 05:59 AM |
Wpl b-16 | MGCrawler | Micro Scale Rigs | 0 | 05-05-2018 07:10 PM |
Azzmans latest latest Tube Chassis | azzman | Axial AX-10 Scorpion | 18 | 01-25-2014 09:33 AM |
