09-20-2018, 12:28 AM | #1 |
Pebble Pounder Join Date: Oct 2015 Location: Fraggle Rock, CO
| WPL Snow Tracks
Longshow snow tracks. Are these new? Cant find any info on them, but theyre for all the new wpl models. May be you guys can help. https://www.amazon.com/Longshow-Trac.../dp/B07H4H6RLY $12 !! Are the WPL's and RC4WD axle's hex the same? Considering getting a set for my Gelande2. Sent from my VS987 using Tapatalk |
09-20-2018, 04:11 AM | #2 |
| Re: WPL Snow Tracks
Not the same hexes. WPL are 5mm and not 7mm.
09-20-2018, 12:36 PM | #3 |
Pebble Pounder Join Date: Sep 2018 Location: Canada
| Re: WPL Snow Tracks
Does any one know how to mount these on a wpl? I got the tracks cheap for mine awhile ago but can't for the life of me figure it out.
09-20-2018, 09:05 PM | #4 | |
| Re: WPL Snow Tracks Quote:
from the link, the first picture with the tan truck shown is what i am commenting to: i would ASSUME that the top circular spot(it looks like it has 8 pair of "spokes" sticking off of it) just pops off(?) and then you could mount it just like a normal set of wheels, onto the hex. this was my theory which is why i was asking hex size too. ---- while typing that, i questioned if we'd need to anchor the track assembly, or if the weight of the vehicle helps keep it on the ground and rolls by rotating the gear and not rotating the assembly.. just a questionable thought. | |
09-20-2018, 09:19 PM | #5 |
| Re: WPL Snow Tracks
Well on mine nothing pops off like you were expecting. Theres a 5mm hex on the other side of the track so I tried mounting straight onto the axle with a SUPER long screw that goes through the whole track assembly to axle. Problem is that the whole assembly when you try and put power to the track it keeps trying to rotate the whole track and not the gears which binds the heck out of everything.
09-20-2018, 09:19 PM | #6 |
| Re: WPL Snow Tracks |
09-20-2018, 09:25 PM | #7 |
| Re: WPL Snow Tracks
Well I got a shot of the otherside because I'm sure you were curious. The hex and the big gear behind it rotates which then turns the track. Defiantly a ghetto system lol. |
09-24-2018, 06:56 PM | #8 | |
Rock Crawler Join Date: Jan 2012 Location: Champlin, MN
09-24-2018, 07:09 PM | #9 |
| Re: WPL Snow Tracks Yeah I figured out for the rear axle how it works I think but the front the piece doesn't fit? If you by chance have a picture of the front axle that would be good!
09-28-2018, 07:15 PM | #10 |
| Re: WPL Snow Tracks
Anything new on the fronts installation? Still curious about them in general. Sent from my VS987 using Tapatalk |
09-28-2018, 07:49 PM | #11 |
| Re: WPL Snow Tracks
No not really. I don't know how I would make it work on the front axle. Honestly the whole system is very cheesy, on the rear axle the piece only has one screw to keep it tight and its a clamping design not like screw into the axle anywhere so it could rotate easily. Anything about the WPL models is very toy grade, but that's to be expected with the price point on these things so nothing is worth robbing for another build in my mind.
12-09-2019, 10:59 AM | #12 |
Pebble Pounder Join Date: Oct 2015 Location: Mt. Prospect
| Re: WPL Snow Tracks
It seems like they released a new version because my treads fit on the 5MM hubs. I used JB Weld to mount the adapters to metal WPL axles. This actually worked well. But there is another very stupid part of the system. The screw that secures the tracks to the axles has to rotate against a piece of the track that does not rotate. With the metal hubs, there is no way to put torque on the threads to hold them in place without locking up the drivetrain. I am going to keep working on it but so far, I have wasted a lot of time trying to make these work.
12-10-2019, 11:25 AM | #13 |
| Re: WPL Snow Tracks
I printed these off of on my 3D printer and tried them on another WPL chassis I have. These worked great. https://www.thingiverse.com/thing:3306262 These tracks consume a ton of power. I have no idea how the stock 180 motor turns them when my 370 motor seems to struggle. I am going to keep working with them and see if anything good can come out of it. |
WPL Snow Tracks - Similar Threads | ||||
Snow tracks on a yeti? | j_ride008 | Axial Yeti | 1 | 12-31-2017 03:37 AM |
Snow tracks for Tamiya? | Teamsherman | Tires and Wheels | 1 | 04-29-2016 04:02 PM |
testing out integy snow tracks | 1375 | Axial SCX-10 | 7 | 01-03-2014 05:06 PM |
Clod snow tracks | Gumbajv | Tamiya Clod Buster | 14 | 12-01-2012 01:28 AM |
