01-14-2019, 06:53 PM | #41 |
Pebble Pounder Join Date: Oct 2006 Location: Leaving black marks on Hwy 200
| Re: Asia Tees 1/24 Hobby Plus CR-24 Defender & D1RC Jeep
Ya, i just took advantage of that deal myself.
01-14-2019, 07:05 PM | #42 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
Sweet! They are great rigs, especially for the $ Sent from my LGMP450 using Tapatalk |
01-18-2019, 08:39 PM | #43 |
Quarry Creeper Join Date: Nov 2018 Location: So Cal
My kids and I continue to have fun with our CR-24 Defender. It definitely out-crawls our Barrage. I'm getting over 30 minutes of run time on a 500 mAh 1S LiPo. Voltage is right around 3.79 after that amount of time, which is just great. I haven't tried taking it down further than that. Hasn't really been a reason to. Has anyone confirmed whether these things have Low Voltage Cutoff / Protection? |
01-21-2019, 05:30 AM | #44 |
Newbie Join Date: Mar 2014 Location: Miami
Spoo76 Thanks for the amazingly detailed review. Last night I orded a cr-24 after reading through this post. For me micro crawling started with an impulse purchase of a Temper 1/24 about 3 years ago. I quickly realized this wont due and started modding it by fixing the suspension and adding an rx and esc. It was so much better but still geared a little too high for me. Then I picked up a Rocksta. Added metal gears and have been loving it. Extremely capable. I Also picked up a few sets of rims and lots of tires and a spare rx/esc. MY question for everyone is, can you reccomend a 1s lipo with the correct polarity and plug for the cr-24? By the way, I just got an email from fed ex saying i'll have it tomorrow? Holy moly. If that actually happens I'll be amazed. Big thanks to everyone for all the great info. Cheers. |
01-21-2019, 09:02 AM | #45 | |
Rock Crawler Join Date: Mar 2015 Location: Waltham
| Re: Asia Tees 1/24 Hobby Plus CR-24 Defender & D1RC Jeep Quote:
01-21-2019, 09:13 AM | #46 |
Honestly any battery is fine. You can swap the pins on the plug end without soldering, I just happened to have an adapter that changed the type of plug to JST so I went with that. I'm pretty sure white wire was positive and red was negative, but I'll check tonight. As far as size something between 300mah and 650 would be ideal. 800 will work, but is of course more weight and space. Look for something on HobbyKing or Value hobby. Id expect to pay less than $12 for a mAh. And maybe less than $8 or $10 for a 650 Sent from my LGMP450 using Tapatalk |
01-21-2019, 10:22 AM | #47 |
Also, it looks like a 5 wire servo. Is it any good? I know finding decent 5 wire replacement servos can be a pain.
01-21-2019, 10:23 AM | #48 |
Standard 3 wire servo. Sent from my LGMP450 using Tapatalk |
01-21-2019, 10:31 AM | #49 |
| Re: Asia Tees 1/24 Hobby Plus CR-24 Defender & D1RC Jeep |
01-21-2019, 11:09 AM | #50 |
Thanks Spoo76. I ordered these https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 temporarily until I place a big order for some good quality batteries. I already have a charger. I really just needed something to test with and needed the adapters anyway. They got terrible reviews ,but I wanted to use my amazon credit......lol Last edited by shabbs; 01-21-2019 at 11:11 AM. |
01-21-2019, 11:48 AM | #51 |
I have what looks like the same exact setup with different branding. I got it with a bundle so I know nothing about it, but it's worked fine for my Barrages, CR-24, and Carisma MSA-1E. I normally prefer 2S however Sent from my LGMP450 using Tapatalk Last edited by spoo76; 01-21-2019 at 11:52 AM. |
01-21-2019, 12:07 PM | #52 |
Thanks man. I have a few 2s for my Rocksta. I thought a 2s would increase the speed which I'm not interested in doing. I wanna crawl. Have you noticed much of a a speed increase with the 2s batteries?
01-21-2019, 12:25 PM | #53 |
There's definitely an increase in bump speed, and it's a little more jumpy, but not bad for a stock rig and sometimes having twice the power is worth it. When I get home I'll double check the pinion and spur and see if I can gear it down some more. I'll also try swapping on a DDT predator motor. Sent from my LGMP450 using Tapatalk |
01-21-2019, 03:55 PM | #54 |
I placed an order this afternoon. The wait begins... Now I need to figure out why my Trekker lost all of its torque. I’m thinking the motor may be on its last legs. |
01-21-2019, 03:59 PM | #55 |
Where has everyone been ordering from? Asia t's or AliExpress? I've seen them both go out of stock and come back. Sent from my LGMP450 using Tapatalk |
01-21-2019, 05:14 PM | #56 |
01-21-2019, 05:26 PM | #57 | |
Quarry Creeper Join Date: Aug 2018 Location: Toronto, Canada
Sent from my SM-N950W using Tapatalk | |
01-21-2019, 10:27 PM | #58 |
I FPV'd my CR-24. Reamed a hole in the windshield and mounted a Cyclops 2 split VTX/Cam AIO inside. Plugged in to the pre-wired power lead, and was in business. That camera location gives you get a nice view over the hood, so plotting a long distance course is easy. But it makes it pretty much impossible to see what you're crawling over. The Barrage UV FPV has a better camera mounting position. It's right up front, with nothing to obstruct it. Overall, the FPV experience on the CR-24 is not great, but it was good for some kicks. I also put some tiny lead split shots (weights used for nymphing/fly fishing) in the front tires, which helped noticeably. Today I got in a package from RC4WD with some 1.0" Stamped Steel beadlocks and Rock Crusher tires. This wheel/tire combo is a little bigger than the stockers, and look the business. The Rock Crushers have foams, and so are obviously a little firmer than the stock tires. But they have grip for days, and the added weight is helpful, so I think they're going to be keepers. I will say this, mounting tires on the RC4WD beadlocks is 1000% harder than the stockers. RC4WD Rock Crushers on the left. Stock wheels/tires on the right: I noticed the D1RC Jeep was back in stock at AliExpress, and the CR-24 is back in stock at AsiaTees. Finding it hard to resist ordering a second one. Last edited by boldfin; 01-21-2019 at 10:38 PM. Reason: adding pix |
01-22-2019, 06:35 AM | #59 |
Mine shows up Friday. Had to laugh on Facebook micro crawler group. Most them never heard of this thing and call the Trail trekker the holy grail of the mict ro world. |
01-22-2019, 06:43 AM | #60 |
I wouldn't say that. A few of us have been posting about it since the early pictures were released. It's still pretty new so most people don't even know about it, just like the Barrage. Sent from my LGMP450 using Tapatalk |
1/24 HobbyPlus CR-24 & new 1/18th scale!! - Similar Threads | ||||
Asia’s Best RC shops? | labrathor | Outside the US | 5 | 12-29-2018 12:00 AM |
Shipping from Asia Tees! | phishead1101 | Chit Chat | 11 | 02-15-2016 05:25 PM |
Asia Tees | mudbeast2 | General Crawlers | 44 | 07-03-2015 06:45 AM |
New shocks from ASIA TEES? | heinie_21 | General Crawlers | 4 | 11-13-2012 11:57 PM |
