Go Back   RCCrawler Forums > Scale Rigs General Tech > Micro Scale Rigs
Thread: Need better shocks
Old 11-04-2018, 09:00 PM   #1
Default Need better shocks
Love the truck, all needed options coming.what are you guys using for shocks?this is the friction grease I have used before. red shock kyosho next ones jjrc and or feiyue the blue cap ones seem the best. forget what the blue cap ones are?If these trucks had good bolt on shocks they would be killer.
Sent from my SM-G955W using Tapatalk
chbronco is offline   Reply With Quote
Old 11-05-2018, 11:33 AM   #2
Default Re: Need better shocks
Completely agree. Iím thinking of fabbing my own from brass tubing. I watched a guy do similar for rc hydraulics and think it can be done. Thanks for showing options you did though.
Mestapho is offline   Reply With Quote
Old 11-06-2018, 09:55 PM   #3
Seen on Facebook,a guy put a
Piece of shrink tube stuff used on sloderd wire joints.on the piston heated it trimed it top and bottom increacing the diameter of the piston,then used friction grease.Seemed to work good will try it.
