12-31-2018, 12:22 PM | #101 |
RCC Addict Join Date: Sep 2010 Location: Apollo Pa
| Re: Kincer's mini Yota
Back together, looks less toyish now, in my opinion anyhow lol |
12-31-2018, 12:46 PM | #102 |
Rock Stacker Join Date: Nov 2018 Location: Fort Lauderdale
Looks good! How do you like the stock servo? Would a smaller metal geared one do better?
12-31-2018, 01:45 PM | #103 |
| Re: Kincer's mini Yota |
01-02-2019, 07:11 AM | #104 |
01-03-2019, 04:43 PM | #105 |
Finally got some painting done, its painted in primer gray with a black backing on the inside to get rid of the red when you look underneath. I did light gray primer because I screwed up the body on the driver's side with a heat gun trying to un warp the front part of the bedside and I ended up making it worse. I got it better but not perfect and would've been real noticeable in gloss or semi gloss paint. Those little taillight decals were tricky to get on right, tweezers and a small piece of plastic are you friends lol. Still need to paint tool box. I scuffed the camper top to take the gloss off and make it look older and chalky. Still waiting on my Esc's so I'll keep detailing it til they arrive. |
01-04-2019, 07:32 AM | #106 |
Looking good. Just make sure you put the fenders on the inside |
01-06-2019, 10:27 AM | #107 |
Esc's should be here tomorrow, got some more details done. It's time to start on the C14 now. |
01-08-2019, 07:40 AM | #108 |
I got four esc's delivered yesterday, 2 30 amp minis from eBay and 2 Hobbywing 1625s, bench tested the 30 amp ones last night and they work great just plug and play. I will install the 30 amp in my Yota tonight with the 180 motor and do some testing.
01-08-2019, 02:50 PM | #109 |
I installed the 30 amp esc with the 180 motor, can only run 2s with this esc so I ran the stock 2s that came with the truck. it's slow but very torquey, with the front wheels weighted it climbs like a goat, crawled right through my rock garden with river rocks. Very happy so far, very cool little truck! I may try the 2spd in it tomorrow. Truck is still mostly stock other than the esc, radio, and steering links.
01-08-2019, 02:51 PM | #110 | |
| Re: Kincer's mini Yota Quote:
01-08-2019, 03:11 PM | #111 |
01-09-2019, 07:05 AM | #112 |
| Re: Kincer's mini Yota I have the dual N20, the speed is about equal to the 2 speed's low gear. The gear spread is quite dramatic, it will chirp the tires. I would say the speed in high is equal to a human jog. I dont see a need for 3s with the 2 speed. I have my Lunchbox and Rally car for speed cravings, this one can stay nice and slow.
01-09-2019, 07:08 AM | #113 | |
01-09-2019, 10:31 AM | #114 |
01-09-2019, 10:41 AM | #115 |
01-09-2019, 12:16 PM | #116 |
Rock Crawler Join Date: Dec 2007 Location: MERICA!
Curious to see how the n30 does on 3s. I had the n20 set up and on 2s its extremely slow, absolutely no wheel speed. I also blew one of the little gear boxes in my living room. |
01-09-2019, 12:19 PM | #117 |
01-09-2019, 01:02 PM | #118 |
ok let us know
01-10-2019, 05:10 PM | #119 |
So I tried the 2spd tonight with the 370 motor on 2s with the 30amp esc, lots of fun and the 2 spd works really well, shifts nice and smooth. High gear is much faster than the 180 motor with the stock transmission and low gear is nice and slow and torquey. Not sure when i'll get around to trying the dual N30 motors, I'm definitely gonna try them but might be a bit. So as of now the only upgrades on this truck are the steering link, 30 amp esc, 2spd transmission with 370 motor, front wheel weights, and steel driveshafts. I had to use the driveshafts because the plastic ones would not work with the 2 spd. This thing is a blast! No it's not a 1/10 scale rig that will climb a tree but for what it is it's a lot of fun. |
01-11-2019, 07:14 AM | #120 | |
The only thing I dislike about the 2 speed is how low it sits. I will have to modify the battery tray, but I am going to TRY and design a 10mm riser just to give it a bit more clearance. | |
Kincer's mini Yota - Similar Threads | ||||
Yota mini-crawl by LB Productions | z71baja | Scale Videos! | 2 | 06-05-2016 10:57 AM |
Kincer's new Jeep | kincer | 1.5 Scale Rigs | 30 | 07-10-2014 04:40 AM |
TTC Mini Yota | sheedy126 | 2.2 Scale Rigs | 7 | 02-24-2011 03:01 PM |
losi mini rc yota scalar? | 01tj | Newbie General | 5 | 05-05-2010 02:38 PM |
