Go Back   RCCrawler Forums > Scale Rigs General Tech > Micro Scale Rigs
Thread: Kincer's mini Yota
Old 04-20-2022, 08:10 AM   #141
j0e
Default Re: Kincer's mini Yota
Originally Posted by kincer View Post
1625 fits better, doesn't have a drag brake but with the 2 speed transmission you don't need it. In low gear it'll hold itself on a hill. These things are a blast if you don't mind tinkering a bit to get things just right. They've come a long way in their quality since I got my first two, fit and finish is much better on the newer stuff.
Sent from my SM-N981U using Tapatalk
Well, looks like I should have listened!
With the new trans this thing is quick enough in 2nd that the non-adjustable drag brake of the 1060 makes it stop and lift the rear tires.
Gonna order a 1625 now.
Thanks for all your testing and info.
j0e is offline   Reply With Quote
Old 04-20-2022, 11:06 AM   #142
kincer's Avatar
No problem I like the 1060 but the 1625 is smaller and works well with the 2spd
kincer is offline   Reply With Quote
Old 04-20-2022, 12:18 PM   #143
j0e
I placed my order and it should be here in about a week.
I use this rig as a little trail basher around the yard; not much actual crawling.
Does the 1625 free wheel pretty well when letting off the throttle in 2nd?
Also, was your 2 speed servo awkward to adjust?
I had to max out my endpoints and sub trims on my dx3r to get it shifting properly.
Old 04-20-2022, 04:26 PM   #144
kincer's Avatar
1625 has no drag brake so it will coast in high gear, it coasts very little in low, it will hold itself on a hill with the gears. You can move the plastic arm on the rod to get some adjustments also.
Old 04-20-2022, 04:36 PM   #145
j0e
Yeah. I definitely had to mess with the arm.
Seems to work well even though my servo only moves from 9 to about 6:30.
I can’t get it to 6 o’clock, but it works.
Old 04-25-2022, 08:17 AM   #146
j0e
Got my 1625 installed and it's perfect!
Just what I wanted from this little rig.
Thanks for the help.
Kincer's mini Yota - Similar Threads
Yota mini-crawl by LB Productions z71baja Scale Videos! 2 06-05-2016 11:57 AM
Kincer's new Jeep kincer 1.5 Scale Rigs 30 07-10-2014 05:40 AM
TTC Mini Yota sheedy126 2.2 Scale Rigs 7 02-24-2011 04:01 PM
losi mini rc yota scalar? 01tj Newbie General 5 05-05-2010 03:38 PM
